Where to buy Spohn LCA bushings?
Old 07-27-2008, 06:32 AM
Vetal's Avatar
Default Where to buy Spohn LCA bushings?
As I found out my rear bushings are worn out pretty bad, inner opening is oval. Wheels move back and forward alot. Where can I buy those rear bushings? Those circled in yellow
Old 07-27-2008, 08:40 AM
leadfoot4's Avatar
Looking closely at the picture, especially where the mounting bolt for the LCA is, it looks like the hole in the bracket on the REAR AXLE is elongated...Better check that!
Old 07-27-2008, 09:17 AM
vjo90rs8's Avatar
Good catch! That could definitely be a problem if the bolt is moving around in that oversized hole.
The Spohn bushings can only be purchased from Spohn. I found this out a few months ago when I was looking to replace mine (ended up going rod/rod). They are like $2 or $3 each, can't remember exactly, you would need 4 per LCA.
Old 07-27-2008, 06:20 PM
Vetal's Avatar
Yes those holes are elongated, I'd say 14-16mm long. I thought they allow to adjust position of axle in the wheel wells. Isn't that normal? Bolt isn't moving along the bracket (you can see no traces of this in the pic too), but bushing moves back and forth on the bolt.
BTW this rear is supposed to be Moser 12-bolt.
vjo90rs8?: maybe you have part #'s for those bushings?
Old 07-27-2008, 08:59 PM
vjo90rs8's Avatar
Call Spohn, only way to order them since they arn't on their website.
Old 07-28-2008, 05:03 AM
Vetal's Avatar
will try, thanx although it's kinda difficult with 10 hours time difference
Old 07-28-2008, 08:09 AM
leadfoot4's Avatar
NO!!
That bolt "hole" is simply that, a hole that mounts the LCA, as well as allows the LCA to pivot as the suspension reacts to dips in the road. Although it might not appear to be moving, I'm pretty certain that the power of the engine or brakes can and will, shift the LCA with respect to the axle housing, when accelerating or stopping.
Old 07-28-2008, 12:49 PM
Vetal's Avatar
hm, I don't believe someone elongated the holes just for fun
Old 07-28-2008, 02:39 PM
leadfoot4's Avatar
If, at some point in time, those bolts were loose, the holes could have elongated themselves over time, as accelerating and braking pushed the LCAs back and forth. OR, if the bushings went "egg-shaped" a while back, the movement within the bushing itself could have helped the holes elongate themselves.
Either way, they shouldn't be that way, and I strongly suggest that you address that situation as soon as you can.
Old 07-28-2008, 05:31 PM
Vetal's Avatar
Are these the correct bushings?
http://www.spohn.net/shop/Replacemen...t-Bushing.html
Old 07-28-2008, 05:57 PM
Fedge's Avatar
That is most certainly a Moser 12-bolt. Couldn't tell you why the holes are elongated, they weren't when we installed the rear nearly a year and a half ago. The rear never moved when I owned the car, the suspension was nice and tight. I had no complaints about the Spohn LCA's or that 12-bolt...I'm inclined to agree with these guys, though. Maybe a bolt loosened. Maybe the bushing deformed. I honestly don't know. I haven't seen Chuck (my dearly missed TA in the pic) since May 23, 2007...
Old 07-28-2008, 06:49 PM
Vetal's Avatar
Wow, that's sad. I was hoping you will say holes were like this already... You're sure this isn't a provision to center the rear in the well??
Old 07-28-2008, 10:57 PM
Fedge's Avatar
no, I think they were regular holes. I would have remembered bitching if I had to try and center that thing...job was a pain as it was being on my back and all
Old 07-28-2008, 11:37 PM
vjo90rs8's Avatar
those are the bushings, I guess they recently added them to their website.
Old 08-08-2008, 08:23 AM
Fedge's Avatar
how much to take Chuck off your hands? I miss my car anyway.
Old 08-08-2008, 10:01 AM
Vetal's Avatar
You want to buy it back?
Old 08-08-2008, 10:51 AM
BADD SS's Avatar
They are not supposed to be elongated. Thus replacing the bushings will do you no good, if the holes are out of round. They are supposed to be round holes, there is no provision for adjustment. That is what an adjustable lower control arm is for. Factory rear or aftermarket will both be just a round hole, with little to no slop.
Old 08-08-2008, 12:58 PM
AChotrod's Avatar
get some weld in trailing arm relocation brackets. problem solved. And clean that thing up.
Old 08-08-2008, 01:47 PM
leadfoot4's Avatar
OR, center up the trailing arms in the "newly machined slots", and weld in some heavy duty flat washers, to restore the "holes" that were originally there.
Old 08-10-2008, 08:12 AM
Vetal's Avatar
What is trailing arm?
Quick Reply: Where to buy Spohn LCA bushings?
