lt1 intake manifold
Guest
Posts: n/a
i looked on summitt and i couldnt find it, i was just trying to see if there wer anyother manufacturers tht made a direct replacement, i got tht ****** leak at the back of the manifold. i just figured if i was gonna tske it off might as well put a new one on there
edelbrock makes the only production replacement intake manifold for the LT1s. That being said, there are barely if any gains, so you're almost better just pulling your intake, checking the seating surface for warpage and if alls okay, put it back on with good gaskets and a good amount of Silicone
Guest
Posts: n/a
I wouldn't suggest a single plane for a NA car making under 450 hp or so. Unless they are looking to improve high rpm power at the expense of low end torque.
A ported LT1 intake can support upwards of 500hp before it becomes a huge restriction on a non forced induction application.
To the OP's request If you are still on stock heads I would just replace the intake gaskets and insure you have the lifter valley sealed when you replace them. The key is dropping the intake straight down and not sliding it back and forth before bolting it down.
I agree!
