Took my side moldings off.. and it appears as though my car has been repainted :(
I took off all my side moldings. And all the paint was fine until I got to the small piece on the rear drivers side. The color is slightly different. I dont know much about paint work, but it appears as though the rest of the rear fender has "more" clear, I can even scrape it off. How much would something like this cost to fix?
It sounds like the panel was blended to the seem (the door jam.) The wife's TA was that way...luckily that little piece is what I pulled off first and found it. I just got some double sided tape and stuck it back on. Thats really all you can do unless you are brave enough to do some major wet sanding...and risk ******* it up worse than it is.
Same happened to me. I went to take off my side moulding.. The one on the front fender came off and looked great, I was excited to see the rest of it off. Get the whole damn driver door moulding off and then get to the rear 1/4 to find that it was repainted and looked like **** under. Had to get some more tape/glue to put it back on. I was pissed.
I was trying to take my side molding off about a year ago, and the first little strip i took off was on the passenger side. The paint underneath was Sebring Silver metallic. I was sad.
My front fender was repainted by the previous owner with the side molding on. When I took off the side molding it really looked like ****. I liked the look of !side molding too much to put it all back on. I wet sanded the area, used rubbing compound, then polished it. It looks great now and you cant even tell it was repainted.
The reason why they were on, is because when tony got it, it was like that. He tried totake it off and noticed it was painted, so he bought new moldings and put it back on.
I remember specifically asking him why he hadn't taken them off when I cleaned up his car.
i had the same problem with my car. I took off the side molding and it was a diff color and a ring of brown around it. Found out that half the car was repainted.. I was so mad!!!! i ended up having to repaint it again
Cant find the camera. Think my roommate took it to the body shop bc hes getting the grip tuning front end put on his srt8. I'll take pics as soon as he gets back.
i just cant believe how many cars were painted without the moldings being removed first! then again, i got the macco special on an old beater and they painted over my pin stripes.
