broken header bolt....what yo think?
Old 08-10-2008, 06:17 AM
back in black's Avatar
Default broken header bolt....what yo think?
well, when i got my lq9 i noticed that the rear bolt on the passenger side was broke off flush.
i was like, ok, i gotta extract that before i put it in.
well months later, the engine is assembled, and it and tranny is bolted in the truck for good.
went to install headers and guess what....... damn broke header bolt still there.
i am using the sanderson s10 headers, with gobs of sealant, question is, will it hold? or should i pull the header, and drill/xtract.
i can get to it fairly easy from under the fender, (no fenderwells)
Old 08-10-2008, 06:22 AM
jomomma's Avatar
if you had problems you could unbolt one motor mount and jack up the motor a little for easier access.
Old 08-10-2008, 06:49 AM
yeah, but i have a fairly clear sightline to the bolt from under the fender, now that i think about it, i might be able to extract it without removing header. just drill and extract. i will try that.
Old 08-10-2008, 06:53 AM
jomomma's Avatar
if you have clear sight of it and still have problems, find a right angle drill. they work great in tight spots.
Old 08-10-2008, 07:12 AM
yep. i think i will be able to fix it easy tomorrow. i dont wanna take a chance.
i just didnt wanna have to pull the damn engine again.
Old 08-10-2008, 02:32 PM
Lt1Porsche's Avatar
best bet is to just do it right the first time and drill and extract.
Old 08-10-2008, 02:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I was curious why you didn't remove it same day you saw it?
Old 08-10-2008, 04:26 PM
took it to the shop and set it aside. i had other things to do.
never thought i would forget?
