Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
how to tell if a 1969 z28 is a true cross ram car?
Old 08-11-2008, 01:06 AM
sidewayz28's Avatar
Default how to tell if a 1969 z28 is a true cross ram car?
i have a friend who just purchased a 1969 z28 with a crossram and JL8 package.. So far the numbers are matching, but is there any code on the tag on the fire wall (or anywhere else) that will prove its a TRUE cross ram car? I know the front rotors should be 11 3/4" in diameter, but other then that how can you tell? Can we get the vehicle history from GM??? thanks!
Old 08-12-2008, 12:27 AM
Elite_Hot_Rod's Avatar
I have a 69 but not familiar enough with the Z28 and even more so a cross ram set up so I'm not sure if the intake numbers would give that indication or not, might be date coding? Does it have the Winters snow flake on the intake manifold? Go here and ask your question, those guys will know how to help you.
http://www.camaros.net
Old 08-12-2008, 12:35 AM
sidewayz28's Avatar
the upper and lower intake are both stamped w/ the snowflake.. i believe after july 1969 the cross ram was discontinued..might be wrong.
Thanks though, ill post up there.
Old 08-12-2008, 02:12 PM
yodas little brother's Avatar
check the rearend for vin# to make sure of the jl8,hood should be floppy fiberglass with a prop rod,its hard to tell they were dealer options.could be a clone there making those intakes repo pretty good now.how much did he pay?
Old 08-12-2008, 03:32 PM
sidewayz28's Avatar
its a steel hood
Old 08-13-2008, 11:38 AM
Hylton's Avatar
It is impossible to tell if a car was originally a cross ram car because they were all dealer installed items. The only way to know for sure is if it came with the original bill of sale that has the cross ram set-up clearly on the invoice.
Since you state the hood is steel, his set-up is most likely from Heartbeat City in Michigan which produces complete cross ram set-ups which even have the original part numbers and '69 dates stamped in them.
Also look for a TI ignition which most guys who bolt on cross rams seem to forget to put on the car.
Old 08-13-2008, 12:17 PM
sidewayz28's Avatar
thanks hylton
Old 08-13-2008, 01:05 PM
VIN is not on a rearend and IIRC JL8 is the code for a big block which would not have come with cross ram, only a 302 would have had cross ram.
Old 08-13-2008, 01:11 PM
sidewayz28's Avatar
JL8 is a code for 4 wheel disc brakes
Old 08-13-2008, 02:38 PM
I knew I forgot, I need to get back into the 1st gen stuff, my 69 has been sitting in the garage to long.
Old 08-13-2008, 02:42 PM
sidewayz28's Avatar
1st gens are way too nice... if i could have my whole drivetrain in a 69 z28 i would die! (hopefully not literally!)
Old 08-13-2008, 03:05 PM
Hylton's Avatar
I plan on doing an LS1/M6 swap in my '69 SS ragtop. Stay tuned....
Old 08-13-2008, 04:10 PM
I thought I recognized your sig from Team Camaro. Over there I post as Old Man.
Old 08-14-2008, 11:30 AM
Hylton's Avatar
It is I!!! I'm in love with all generations of Camaros!
Old 08-15-2008, 09:33 AM
I have my 69 Camaro and an 8 second 99 T/A, just sold my 99 Z28. Looking for a good 67 Camaro BB coupe now.
Quick Reply: how to tell if a 1969 z28 is a true cross ram car?
