Just dynoed my TT ZO6
I just bought this car last week so I took to the dyno to see how much power this thing have I still waiting for the builder of the car to arrive so I can have all the info on the car.
01 ZO6 with less 30k miles
Mods that I know:
Engine:
Build 346ci 8:5.1 compresstion, MTI Stg 2 heads, custom turbo cam, all valvetrain.
stock trans and rear.
STS TT ZO6 dont know the size but the owner said they are the biggest turbos STS offer.
Fule system
with 9psi and Air/Fule ratio 10.0 all the way to 6000rpm and 13.0 after 6000rpm to 6400rpm (thats whan I let go)
The car made 499rwhp 476rwtq SAE with hot wheather.
We tried to tune the car but the tune was locked
What do you guys think about the numbers Oh I also found all stock Cats and stock H-pipe are stil on the car????
I will remove the CATS and add 3 X-pipe (stock headers) and retune with 13psi
Any comments will help
Mods that I know:
Engine:
Fule system
Nice man. Sounds like you've got some work ahead of you to get everything running right, but a TT Z06 is a good platform to start with. I've never been too impressed with most of the STS kits out there, but setup right they can do some damage. Either way, it's way more power than I'm putting down and in a much lighter car, so congrats on that!
wrong....you want it between 11-11.5:1 to keep it on the safe side for a street car on pump gas.
and wrong.....this is a turbo car not a blower car.turbo street setups like his running up to around 15psi should have between 8.5-9.0:1 CR.he just bought the car already setup like this,why would he go tearing into the car to raise the CR?
8:5.1 Is the best compresstion for TT street car with pump gas,
I have the the dyno sheet I will post it tonight the owner is a friend of mine and I wa there when dynoed the car and made 705rwhp 659rwtq with 14psi mix fule 91/109
I'll let you know in two weeks I want 650rwhp+ on pump gas
Thanks.
Thanks
Thank you the car already made 701rwhp 669rwtq Here is the graph maybe you can give some help from dyno graph do you think there is more left in it
Thanks guys here is the best dyno run with 14psi 91octane mixed with 109octane
Thanks
The strip will open next months but the street is always oped
