05 GTO TSP 427 L92 Stroker at idle
This is a day after install of my 427 stroker from Texas Speed. The sound is absolutely mesmerizing.
http://www.youtube.com/watch?v=hO-K7N3C8rw
Man I would be scared to be next to that thing. What a beast! I saw the other vid of you on the dyno. For the sound though, I thought you would have dynoed higher then 500hp. Still 500hp more then mine.
Its a Texas Speed 427 L92 Stroker. L92 heads, Cam is a Crane cam 632/632 250/266 112.
I think my stall is probably skewing the numbers becaue it was flashing at over 5k on the dyno. That can't help anything. We hit 534hp on one run when the converter locked up. Otherwise it's all there. If I hadnt' moved to Montana, I'd probably see a 10.99 pass or better. The altitude takes quite a bit away from it.
