Western Members CA, AZ, NV, UT, CO, NM, HI
Winding sound?
Old 08-18-2008, 12:44 PM
Ford_Sucks's Avatar
Default Winding sound?
Has anyone had any problems with their cars making a loud winding sound when they accelerate? Im pretty sure its the transmission but im not 100percent so i thought i would ask anyways, see if it has happened to anyone else, it usually gets quieter past 3rd gear, but first second and somewhat 3rd seem to have a loud wind every time i put my foot on the gas
Old 08-18-2008, 01:33 PM
1Loudz28's Avatar
mine whines a lil bit when im accelerating. always has since i got it.
Old 08-18-2008, 01:35 PM
ss.slp.ls1's Avatar
I don't know about winding, but my car used to make a noticeable whining noise when I got on the gas...turned out to be a hole in the rubber hose connecting the pcv valve to the intake manifold.
Old 08-18-2008, 04:49 PM
camarojunky74's Avatar
sounds like its your diff.
Old 08-18-2008, 05:38 PM
ae13291's Avatar
is it 6 speed or auto? could be a problem in a manual gearbox or could be the whining of the power steering pump, if the fluid is old as hell or low.
Old 08-18-2008, 09:35 PM
letsrun97z's Avatar
check the whipple lube
Old 08-18-2008, 10:55 PM
Ford_Sucks's Avatar
its a manual, and it seems to be getting worse, haha, i'll start checking fluids and such tommorow
Old 08-19-2008, 02:59 AM
80'sbaby's Avatar
i remember i used to have a whining noise when i first got the car...hmm i actually just realized that it went away
Old 08-19-2008, 11:40 AM
m6ttop's Avatar
mine whines a little too...always has
Old 08-19-2008, 12:27 PM
SSMOKIN_Y2KSS's Avatar
mine whines all the time...solid motor mounts...over 90 on the freeway the trans sounds like a baby...and then the good ol 12 bolt 4.11 gear whine..but i say its prolly ur diff making the noise...did u check ur trans fluid?
Old 08-19-2008, 01:19 PM
Ford_Sucks's Avatar
not yet, school just started back up and work is killin me, so i gotta wait til this weekend to start checking everything over again, fluids are the first thing im gonna check.
Old 08-19-2008, 02:13 PM
Ford_Sucks's Avatar
hwy, possibly a dumb question, is there another way to check transmission fluid or do i just have to jack it up, and undothe second cap or whatever on the transmission? And also if it is low when i check, whats the best transmission fluid to be putting in? Also i dont have to drain it right? i can just fill it up with the new stuff?
Old 08-19-2008, 02:29 PM
ss.slp.ls1's Avatar
No. If you find that it's low, depending on the miles, it might be worth draining and refilling with fresh Mobil 1 synthetic ATF.
Don't forget to check the diff fluid while you're under there.
djsanchez2's Avatar
^^^ nope, gotta pull the plug, and regular old ATF III works fine. Some like the synchromesh better.
Old 08-19-2008, 06:02 PM
Ford_Sucks's Avatar
sounds good, i'll have to do that this weekend, damn, haha
Old 08-19-2008, 10:37 PM
Ford_Sucks's Avatar
ok so new proble, i got some time tonight, went to check it out, and my car is to damn lowered, i cant even get a jack underneath it to lift it and check the transmission, any alternatives other than taking it to a mechanic? i dont wanna waste money when im broke so some mechanic can screw me over and overcharge me.
Old 08-20-2008, 07:48 PM
BigDaddyBry's Avatar
Mine does. It whines "don't drive me so hard" "take it easy" "you almost hit that elderly lady crossing the street".
******* car doesn't shut up.
Old 08-20-2008, 09:41 PM
ae13291's Avatar
drive it on some 2X4's or use rhino ramps. i used some wood blooks when i went to my buddys lift
Old 08-20-2008, 11:57 PM
Ford_Sucks's Avatar
I have ramps but i cant drive up em from the front because it is so lowered that the front bumper wont allow it
Old 08-21-2008, 01:32 AM
ae13291's Avatar
wow amazing, go buy a low profile jack from costco, thats where i got mine
Quick Reply: Winding sound?
