help changing rear axle
- Put the car on jack stands
- Pull the differntial cover and drain oil
- Remove the wheel
- Remove the caliper
- Remove the rotor
- Remove the 5/16" cross pin bolt
- Remove the cross pin shaft or paddle
- Push axle inwards from the flange so the c/clip will drop
- Remove c/clip
- Slide Axle out
- Reassemble in reverse order
Note: Be sure to use loctite on cross pin bolt threads after you have cleaned with brake cleaner.
Jeff
- Remove the wheel
- Remove the rotor
- Remove c/clip
- Slide Axle out
Jeff
C-clip
-Remove the 5/16" cross pin bolt in center section
- Remove/pull out the cross pin shaft or paddle
- Remove c/clip
- Slide Axle out
- Remove c/clip
- Slide Axle out
