Take a look at bumper and door please
My door has been just nipping the fender when I open and close. The other day I pulled out of the gas station and didn't have the door closed while I was making a right hand turn. The door swung open pretty damn fast and BAM, that is what I got. Being a glass door and the location of the damage, will this be a easy fix and will I be able to make it look like nothing ever happened?
Now for my bumper that I am working on. I have it all sanded and primered. There were some some small nics that I filled with some spot putty that I still need to sand down. So don't mind those. But for the parts of the bumper where the black is coming through, will it be ok to spray the base coat over the bare bumper or should I primer those couple of spots also?
The door would be an easy fix if you take off the fender. My driver's door was broke at the bottom and with a little fiberglass resin, you can never even tell it was there.
By the way I'm an actual collision technician.
