Conversions & Hybrids - what radiator hoses for a body?
thunderstruck507
08-21-2008, 06:41 PM
I lost the link I had on here, someone had part numbers for radiator hoses that work with the factory radiator and LS1 I believe
anyone have those handy?
thanks
thunderstruck507
08-26-2008, 09:50 AM
am I mistaken?
HOTRODKEV
08-26-2008, 10:02 AM
What radiator hoses are you looking for?? Do you mean an F body?......title of thread is a little deceiving
pist0lpete
08-26-2008, 10:05 AM
What I did was bend some coat hangers to roughly the shape i needed and went up to the parts store and compared them with the wall of hoses. I am not near my car right now otherwise I would give you the part numbers I used.
thunderstruck507
08-26-2008, 10:10 AM
A body, chevelle and such
I found some numbers on here with a search but they weren't as "definate" as the ones I seem to remember reading about.
One thing I'm curious about is that I'm pretty sure the outlet on the ls1 water pump seems smaller than the radiator
bczee
08-26-2008, 12:10 PM
I just used a 98' Z28 Camaro Lower hose and with a little trim it fit ok..! don't recall that number but it was Goodyear hose..
The upper I also used a Goodyear, #26347x but added another hose of the same size in just a 90 Elbow to push the hose away from my CAI tubing. Else it would have worked without the 2nd piece added. I think it was also a 98' Z28 Camaro hose..?
ls1_chevelle
08-26-2008, 02:00 PM
Stock Tahoe upper and lowers fit my car just fine. I am using the truck water pump though... Maybe cutting a upper truck hose? Lower should work. Parts store, ask for a lower rad hose for a 2004 Chev 1500
GOLDRUSH98
08-26-2008, 02:12 PM
Here's my setup:
Upper Hose - stock F-Body from P/S cooler to motor, 90 degree hose
from GATES (unsure of P/N) from P/S cooler to radiator
& trimmed to fit.
Lower Hose - Gates hose P/N 22437 (trimmed slightly)
Heater Bypass Hose - Gates hose P/N 42570187
Steve VanS
08-26-2008, 03:20 PM
Visualize your set-up from radiator to engine. Make a few measurements & write them down. Go down to NAPA or other, tell them you're doing a swap and need to pick out hoses for your application -- then go cross-eyed looking at the 100's of hoses hanging on their wall. We used several different hoses, spliced together for our swap. Works good!
thunderstruck507
09-02-2008, 09:39 PM
The stock camaro hose actually has the right bends but its too small around, so I guess I'll just go look at something similar that fits my radiator outlet diameter and get that
found a lower hose
I'll post part numbers for what I find
ryanvv355
09-02-2008, 10:08 PM
Lower hose from a truck works great just needs a trim.
Eric Anderson
09-03-2008, 09:02 AM
I think you are recalling my post for hoses I used in my 68 Cutlass LS1 project. They worked great. Check this linnk out for part numbers and pics:
http://ls1tech.com/forums/showthread.php?t=899506&highlight=
PM me if you need any help.
Eric Anderson
thunderstruck507
09-03-2008, 11:09 AM
Eric Anderson
yup that was is, thanks a million man!
