is 25*degrees enough timing to spray 150
Old 08-22-2008, 10:47 PM
hnaskoct's Avatar
Default is 25*degrees enough timing to spray 150
when i got tuned my timing was at 29*, thats like as much timing as you can put in before you get some pinging but besides that its at 25* now is that enough degrees to spray a 150 wet shot are do i need to take out more
Old 08-23-2008, 01:01 AM
jetlag's Avatar
Well, all cars are different..lots of variables....
Did you see any knock retard?
Old 08-23-2008, 04:37 AM
AutoRoc's Avatar
Most reccomend pulling 6 degrees for a 150 shot...they do it for a reason..It's safe and still runs good. Don't try to run the ragged edge..it's not worth much power and it can make for a bad day.
Old 08-23-2008, 10:13 AM
Hennytime's Avatar
stock timing is fine, i pulled 2 degrees myself for safety
Old 08-23-2008, 03:27 PM
bad6as's Avatar
ide pull 1-2 more
Old 08-23-2008, 03:55 PM
02 BLK WS6's Avatar
If you have a wideband and a way to log with 25*, it would certainly be worth a try. On a 150 shot I run 24* and on a 200 shot I run 22*. I aim to have my AFR between 11.0-11.5 on both shots.
Don't forget about spark plugs either. TR6 or 103 is ok for a 150 shot. I run AR94 since I spray 200 most of the time. I always use a plain copper core.
Old 08-23-2008, 08:43 PM
5_02ls1's Avatar
any other mods???if your just bolt ons or stock and spray 25 is fine
Old 08-24-2008, 09:34 PM
gsxr1k2's Avatar
Been runnin mine at *26.5. Over ten bottles through it and efi live logged twice with no problems.
