Nitrous Outlet is the Direct port Specialist!!
I know I have not shared any pics in a while so I thought I would share these...
This first intake is a Beck intake with three stages of nitrous. One stage is a 4 solenoid with rail upgarde plumbed on the out side of the intake. The second stage is plumbed under the intake with a single rail upgrade and two solenoids. The third stage is a Custom Nitrous Outlet plate located between the upper and lower intake. This set up is capable of spraying well over 1400 HP of nitrous.. Yes maybe its alittle over kill. Naaaa..lol
This next intake is a beck intake powder coated black. This intake is also plumbed for 3 stages and capable of over 1200hp worth of nitrous between the 3 stages. First stage is a 4 solenoid directport with rail upgrade. The second and third stage are all plumbed into a custom Nitrous OUtlet designed plate located between the upper and lower intake.
This intake is a LS7 Manifold with a Nitrous Outlet 2 solenoid Directport. Capable of spraying up to 500 HP worth of nitrous.
Stay tuned for more as I get pics taken care of.
Thanks
Dave
Thanks
Dave
Guest
Posts: n/a
-Chris
