St80 Results Inside!!!!!!
Old 08-26-2008, 09:05 PM
ninetres's Avatar
Default St80 Results Inside!!!!!!
Quick re-cap of my build for newbies :
370ci LQ9 ~9.1:1
AFR 225
Big reverse split cam
T4 ST80 w/ race cover and 1.1ex
TH400 w/ fuddle 3k stall
9" rear
Alkycontrol dual nozzle kit
Tune went GREAT. Rick at Synergy Motorsports tunes my car for those who don't know. Car made 12.5psi on the 10 lb WG spring. It was pointless trying to tune it on the street since it spins too hard to load it properly so he used his dyno pack ( I think he was scared ). He says the numbers are COMPLETELY insignificant considering how his dyno loads my car and that I have an unlocked converter TH400.
Car maxed his dyno on the first pull but that is just from the converter flashing and turbo hitting so hard/fast. He had to tune it rolling into the throttle very easily. A/F is low-mid 11s all the way across @ WOT. He said it is MUCH stronger than my last set-up and should be able to drive into the mid 9s once I get A LOT of seat time. For those who are caught up on imaginary numbers: 699whp/975wtq rolling into it. But again, these are just "numbers". More than enough power for me to get used to the car again. It is quite dangerous as it is. Any more boost and it needs to be tuned on a track or dyno dynamics dyno.
Big thanks to the following for all of their help on this build:
Matt @ Caliber Customs for all of the fabrication/install
Elky489 (Nathan) @ Fresno Performance for the engine build
Rick @ synergy for the tune
Jose/crew @ forcedinductions.com
Julio @ Alkycontrol
And the many sponsors who I have made rich over the past year getting back on my feet
Questions?
Old 08-26-2008, 09:09 PM
theblur98ss's Avatar
Glad to see your car back up and running. I think you're one of the few that have worse luck then me.
Old 08-26-2008, 09:18 PM
bd2bonez06's Avatar
congrats. setup sounds mean
Old 08-26-2008, 09:21 PM
Coal Mining Director
onfire's Avatar
Great numbers.
Old 08-26-2008, 09:49 PM
quicksilverado's Avatar
Tq is insane. When are you going to the track?
Old 08-26-2008, 09:56 PM
ninetres's Avatar
Numbers guy eh? lol
Might make it on the 5th if my funds allow and I can get a wide band by then.
Old 08-26-2008, 10:08 PM
trans2000am's Avatar
torque is nice, im almost done with my t6 st80 build from josh at kentucky
Old 08-26-2008, 10:19 PM
Photochop's Avatar
Did you guys not read his post?? Thats a converter spike!
Nonetheless, nice work man on a killer build. Guess the headaches and hassles arent a big deal and are well worth it now...and plus you can tell people it made damn near 1000 lb ft of torque and watch their jaws drop
Can't wait to hear some track times
Old 08-26-2008, 11:48 PM
RooRnZ28's Avatar
nice to hear its running again... now we need some vids!!
Old 08-26-2008, 11:59 PM
Frost's Avatar
Glad to hear that it is working out for you. It's a stout setup, I bet that thing comes up fast. Make some nice videos.
Old 08-27-2008, 06:56 AM
LS1Tech Sponsor
hellbents10's Avatar
It will be cool to see how she runs down the track, sounds stout.
Old 08-27-2008, 08:59 AM
LS1TECH Sponsor
DrTurbo's Avatar
370ci LQ9 ~9.1:1
AFR 225
9" rear
Questions?
Glad you like your ST80........that torque # is sick...lol A unlocked TH400 will eat hp BIG time. 700rwhp with that tranny unlocked is BIG #'s with a 6spd.
Old 08-27-2008, 10:07 AM
ninetres's Avatar
On only 12.5 psi
OMG. I just realized I forgot to add you in my thank you section!!!!!! You guys took GREAT care of me through this whole build! Added!
Old 08-27-2008, 10:21 AM
LS1TECH Sponsor
DrTurbo's Avatar
On only 12.5 psi
Lol....no biggie. We try to get everyone taken care of. . That's what we are here for!
Old 08-27-2008, 11:17 AM
30th t/a's Avatar
I bet that thing is insane on the street, jezzz!
Old 08-27-2008, 01:25 PM
LS1TECH Sponsor
DrTurbo's Avatar
Dang...just saw it was at only 12.5psi.....
Old 08-27-2008, 02:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
Very nice, now go run some 145+ passes!
Old 08-27-2008, 02:48 PM
Photochop's Avatar
Hey DrTurbo, is this a pretty common or 'expected' rwhp figure for similar combinations with T4 ST80 units? I know the numbers don't really count for much, but 700hp thru a th400 is pretty stout regardless.
I guess what I'm getting at is would a T4 ST80 be overkill or too big for a 347 inch motor? How does the case size compare to a 76GTS?
Old 08-27-2008, 04:13 PM
ninetres's Avatar
I used to have a T76gts and my ST80 bolted right onto my crossover. It couldn't be ANY bigger though. The turbo would be grat for a 347 IMO......with a TH400 of course
Old 08-27-2008, 04:28 PM
NA$TY-TA's Avatar
Bad *** man... dont worry about the Dyno #'s..... get her to the track.....
Quick Reply: St80 Results Inside!!!!!!
