6.0L limits
Old 08-28-2008, 01:33 PM
Juicemonkey's Avatar
Default 6.0L limits
Hey guys I have saerched and found a few differant answers to the limit on the 6.0L when turbo'ed. My question is what is the stock crank capable of holding, I am only shooting for 600hp tops, pistons and rods I will change out to forged units but can the factory crank hold or should i suck it up and dish out for a new unit? I would like to keep stock stroke, no need to go to a 4 inch stroke.This powerplant will be low boost application well less than 15 psi on a 76 mm huffer. The donor vehicle is only 2500 lbs so I will nto need much just want to find the weak links so I have as dependable power as I can get. Thanks.
Old 08-28-2008, 01:36 PM
67Firebird455's Avatar
Stock crank is fine at that power level, as long as you're not spinning it up to 8 grand or anything. Also, 2500lbs and any boost (600rwhp) is gonna haul *** man. What kind of car?
Old 08-28-2008, 01:37 PM
rubbersdown's Avatar
Stock crank has been proven to handle 1000+HP, you will be fine at 600.
Old 08-28-2008, 01:58 PM
Thank you very much thats what I was hoping to hear. This is going into a 240sx I have a Ka-T in it now for the last 4 years and made 523 whp but it isnt reliable on such a small motor, its fun and fast as hell but we always want more dont we,. Plus a 6.0L is just badass! Planning on using a Ls6 cam and car intake for it with 60# squirters and a 76mm huffer. the car already has a fuel system and intercooler setup on it anyway so I wont need to do much.
Old 08-28-2008, 02:00 PM
That's perfect man. 6.0's and LS6 cams in turbo apps are an inexpensive way to haul some serious ***. 60# injectors will be perfect if you're staying 600whp or less, and a 76mm turbo should be sick as hell. Can't wait to see more on this car! >=) How big an intercooler does it have currently?
Old 08-28-2008, 02:02 PM
with end tanks its 36 long 3 thick and 12 high. I am blowing 30 plus psi into the current setup now to make this power level I am going to love 15 psi or less and same power with more tq.
Old 08-28-2008, 02:03 PM
That is so freakin awesome. That's a long sob intercooler! About what... 28-29" core? That's pretty decent sized, should work out great with the new setup!
Old 08-28-2008, 02:06 PM
something like that.
Old 08-28-2008, 03:36 PM
HUNTER02SS's Avatar
1450fwhp with my stock 6ltr. crank at 26psi!
Old 08-28-2008, 07:43 PM
Gordon0652's Avatar
Like said above, stock crank should be fine. And you do not want to spin it that high also unless you have it seriously balanced by the time you get it balanced i rather have a Compstar crank for piece of mind.
Old 08-28-2008, 08:25 PM
gametech's Avatar
I know iron blocks can be found cheaper, but I would try to find an aluminum 5.7L just to keep the weight down on the front of a 240.
Old 08-28-2008, 11:04 PM
that was the plan but I got the 6.0L for free. cant beat that. and I would only try to rev to 7k, upgrade the valve springs and pushrods. I should be ok at 7k right? thanks guys for your info.
Old 08-28-2008, 11:12 PM
the iron 6.0l block is only about 60-80lbs heavier than the 5.7 aluminum block. With yur aftermarket parts and what not I bet yull be at about the same weight as the stock alum. block
Old 08-29-2008, 12:06 PM
Have a good balance job done, and obviously good rod bolts (which will come with your forged rods). With a turbo, you can probably shift the thing at 6700-6800 and be just as happy as 7000. Take quite a bit of cam to notice a spike in power at 7k.
Old 08-29-2008, 12:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Matt Harlan took a stock crank to 8.2x @16x almost five years ago, and Mike Brown maybe took one to 8.4.
Quick Reply: 6.0L limits
