my 97 TA rear tires wear on the inside why?
i just got my trans am about 4 months ago and I've already gone through a set of tires. now the car has been recked before by the previous owner but they replaced the axles. and the alignment is out but seeing how it is a solid axle there isn't any adjusting it so should i replace the hole housing because it may be bent or is their something els i should check that would cause the alignment to be out?
I'll check the axle bearings, and the car was hit on the passenger side door so i don't think that may have had a effect on it because the axle's not tweaked it's just a toe and camber problem. and a buddy of mine just informed me that i can git a rear end alignment and that the place i took it to just didn't know they could.
