Lid...
Old 08-30-2008, 12:48 PM
Bouvs's Avatar
Default Lid...
Well I've long since had an SLP lid and ofcourse the fitment sucks... anyway I could deal with it but I might be upgrading my whole intake side and so it might be a good time to try out the FastToys85mm lid just wondering if anyone has tried it? particularly has anyone made the switch from an SLP to the FASTTOYS Lid and how much better if at all was the fitment?
Old 08-30-2008, 03:40 PM
00pooterSS's Avatar
You do realize the 85mm Fast Toys is for a 85mm MAF right? I was under impression the SLP is for the stock MAF. If thats the case then the FTP wouldnt work for you.
Old 08-30-2008, 03:44 PM
firefighting1101's Avatar
yeh there is no reason to switch to an 85mm lid unless you have an 85mm MAF
just a waste of money
Old 08-30-2008, 03:50 PM
Predator's Avatar
SLP lids fit great if you make sure that the tray below the filter is seated correctly, and the front lip of the lid is tucked-in. My SLP lid fit terrible before I figured-out the problem with the under filter tray.
Old 08-30-2008, 04:10 PM
thislswon's Avatar
i was going to say i have had MTI,LS1 Motorsports and SLP and it fit the best and i have always heard people say SLP is the best fitting lid....took me 15 min to install my SLP lid
Old 08-30-2008, 06:11 PM
Bouvs's Avatar
actually you can get adapters to have the 85mm lid fit with the stock maf but I am intending on upgrading the maf too if I decide to get this lid which I still have no idea because no one has answered the damn question...
how does this damn thing fit... my slp lid fits decently but the back tabs don't go all the way in and so they start to bend and then slip out and the lid begins to lift off that back section ever so slightly... I installed it properly right from the first time.
so anyone going to chime in with some insight as to whether or not the 85mm lid fits better then the SLP or even as well?
Old 08-30-2008, 06:42 PM
00pooterSS's Avatar
All these say alittle about it fitting good this first one says the most, try searching next time, I found these in less than 5 minutes.
https://ls1tech.com/forums/showthrea...=lid+toys+fast
Old 08-30-2008, 07:42 PM
addicted2fun's Avatar
My SLP Lid fits great i have never had an issue with it.
Old 08-30-2008, 09:57 PM
Bouvs's Avatar
wow good call... anyway thanks for the links... feel a little more comfortable about the idea now
Old 09-01-2008, 06:25 AM
SS1875's Avatar
I recently installed the FAST TOYS lid....it does rub on the underside of the hood, other than that the fitment is good if your running an 85mm MAF. I do plan on placing a thin piece of rubber on the hood in the rub area just to alleviate rubbing the paint off.
Suggestion, I used the SLP smooth bellow between my 85mm MAF and 90mm TB, you will need to modify it a bit on the backside though.
Old 09-01-2008, 02:50 PM
00pooterSS's Avatar
this is from my quote further up, Fast Toys chimed in on this one and showed what to do to fix the hood rubbing issue.
Old 09-02-2008, 03:47 PM
BlackNiteWS6's Avatar
SLP's lid does not suck!!! It's made of a much better material than others.
Mine fits great and works great.
Old 09-02-2008, 05:04 PM
Fast Toys Performance Parts's Avatar
Default Fitment
The FT 85mm lids fits really well. We have received a lot of positive feedback on it.
As someone said, you can use it with the stock MAF if you purchase our optional adapter. Then down the road when you get an 85mm MAF, you can just pull the adapter off and not have to get a new lid.
We don't recommend any smooth bellows with our air lid. Since all lids are angled down a bit over the radiator shroud, the smooth bellows tend to pull up the back of the air lid which decreases hood clearance and causes rubbing. The factory, accordian style bellows works best.
We do have a modification you can perform to our air lids to drop them a little bit lower on the base but it is at your own risk as it involves sanding the lip of the air lid.
Old 09-02-2008, 10:05 PM
*98TransAm*'s Avatar
the SLP lid is supposed to be tight to ensure an air tight seal.
