WHAT THE HELL!! c4 swap problems
Old 08-30-2008, 01:17 PM
armyracer11's Avatar
Default WHAT THE HELL!! c4 swap problems
hey i bought conversion mounts today and they dont seem to even be remotely close. Has anyone else had problems out of Carshopinc products?
Old 08-30-2008, 03:15 PM
boondiggys's Avatar
you should contact the manufacturer first, because they are the ones who have the most experience with their product.
Old 08-30-2008, 07:16 PM
i know but cuz of the holiday can get them until tuesday, so just looking for ideas.
Old 08-30-2008, 11:20 PM
bczee's Avatar
What is the problem ?.. or some pictures ...
Old 08-30-2008, 11:30 PM
the_merv's Avatar
Yea.. what you got?
I bought conversion mounts for my Car.. is it not lining up on the Cradle?
That is the problem I ran into, and I had to notch the Bolt holes in my K-Member mounts so I could slide them out wider to fit in my Engine in.
Old 08-31-2008, 12:59 AM
well there are 2 problems......1st the mounts are to wide for the cradle, the 2nd is the motor is 2 inches from the tranny. the C4 has a torkarm like a Fbody, the tranny is still in the car so thats how i know its not in the right place.
Old 08-31-2008, 07:00 AM
the_merv's Avatar
Do you have pics of the Mounts?
To solve the first problem you might have to do what I mentioned in my previous post.
Old 08-31-2008, 09:45 AM
its the tranny problem im worried about
Old 09-01-2008, 06:00 PM
the_merv's Avatar
Do you have a pic?
Old 09-01-2008, 09:12 PM
bczee's Avatar
Without seeing your Mounts and plates or which style they are made from.. I can only say that you have got the wrong ones.. you need one that will place the engine backwards the distance that your trans/engine is apart (2" ?).
or that you need to relocate the engine frame mounts backwards the distance you need...
But those are only wild guess right now, without seeing what your setup looks like.
Old 09-01-2008, 10:17 PM
well i got the mounts to work in the kmember but still have 2inch gap from the tranny?
Old 09-01-2008, 11:16 PM
the_merv's Avatar
Maybe you have the Mount Plates on the wrong side..not insulting you.. just throwing it out there. I've done **** like that as well..we all have.
A pic would help alot though for me to know what you are working with and to give some advice on..
Old 09-02-2008, 09:19 AM
if the where backwards then the gap would be even biger
Old 09-02-2008, 09:05 PM
the_merv's Avatar
Old 09-03-2008, 12:06 PM
LS1TECH Sponsor
Carshopinc.com's Avatar
The mounts are installed correctly, The ls engine trans mounting surface is flush with the passenger head... Traditional sbc engines have a 1 1/2 offset to the trans mounting surface, when you mount a ls you can only place it so far rearward before you run into firewall interference issues if trying to install it to the trans in the stock location. With our standard mounts the ls cylinder head has less that 1/2 inch of clearance from the firewall. It's confusing to explain but since the trans mounting surface is is flush with the head and the trans is in the stock location your only option is to move the trans forward.
Old 09-03-2008, 02:10 PM
i did not post pics because i had already talked to CARSHOP and i understood the problem. i now see how this works and they are right.
Old 09-06-2008, 12:55 AM
72Elkytpi's Avatar
The torque arm holes have to be elongated so the trans can move forward, I know because I have done it on a swap.
Old 09-06-2008, 11:02 AM
thanks i have been trying to figure out how im going to do it.
Quick Reply: WHAT THE HELL!! c4 swap problems
