Car is walking side to side...
I just replaced the rear end in a friends 2001 Camaro. Now when he drives it at normal speed it drives straight. But when he gets on the expressway running 70+ it wants to walk side to side with him. What do I need to look at. Everything under neath is stock, so nothing has been changed..
Thanks!!!!!!!!!!!!!!!!!!!!!!!!
Hopefully the first thing he checked was that the rear tire's pressure is correct. Inadequate and uneven tire pressure can cause a car to wobble at speeds upward's of 65mph.
Does anyone have a picture of underneath their car? He says that a bar is missing that we didn't take off. there are four bolt hoes on the drivers side that at one time had something mounted there.
side to side
Before the rear end was installed it was fine.Put the rear end back now it feels like its fish tailing at 70mph plus. I have checked all bolts and the sway bar. So i guess i will find a upper panhard bar to see if it fixes it .Im not sure what else it can be.Do you think the lower panhard bar would be enough to keep it from swaying. Why do you think it would be noticed now??? THANKS FOR ALL YOUR HELP!!!!!
There's two "channeled" bars that go from side to side to keep the rear-end from moving, the upper is missing. M.I.A. http://photos-g.ak.facebook.com/phot...976054_744.jpg
http://www.bmrfabrication.com/phr/Uphr-installed2.jpg
Panhard bar
I guess its the issue ?I have checked all bolts .Im going to purchase another one install it to see what happens .We are just confused run over a 100 down the interstate before install now i cant get over 80 with it .Again thanks for your help i will respond when i get the other panhard bar installed.
side to side
Ok i checked the axles both are fine c-clips are in so whats left?? I will replace the upper panhard bar .BUT IT WAS GONE BEFORE WE INSTALLED REAR END .I will try that and hope??? I will check back when i install upper bar.
