Those that have asked about Garrett budget units....
Old 09-03-2008, 01:15 PM
LS1TECH Sponsor
DrTurbo's Avatar
Default Those that have asked about Garrett budget units....
The Budget Garrett units are now available...... If you are diehard Garrett guy and not wanting to go with one of our standard budget T6 Borg Warner S400's, this is for you......
http://www.forcedinductions.com/productsgarrett.htm
GT76-flows 101lbs/min
GT80-flows 119lbs/min
GT88 flows 139lbs/min
Old 09-03-2008, 01:55 PM
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by .ALEX.
Good job bringing out new products.
What frames are they being built on?
They are based on the TV frames like every big Garrett turbo in the world....lol, using newer GT parts. Everyone wants a unit compact like the S400, but GT technology comp wheels. Its here...
Old 09-03-2008, 03:03 PM
camaroandreas's Avatar
How is a GT88 compare to a S488?
Old 09-03-2008, 03:05 PM
LS1TECH Sponsor
DrTurbo's Avatar
The GT88 will spool faster and uses a newer comp wheel.
The S488 is a 7 blade comp wheel. Flows about 9lbs/min less.
Old 09-03-2008, 03:29 PM
Cool. how about the outside dimensions? I need a turbo that don´t have more then 1" larger compressor cover then my S480 with standard cover.
Old 09-03-2008, 03:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
Same size.....and actually short in length as well. Will fit ANYWHERE as S400 can fit.
Old 09-03-2008, 04:08 PM
Pat-Man's Avatar
Wow...those are impressive. Might look into picking up an 88 to replace my 76 in the future.
Old 09-03-2008, 04:20 PM
What´s the difference compare to a GT4788?
Old 09-03-2008, 04:23 PM
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by Hennytime
so is this one of those large frame t6 turbo
No...its a mid frame. Like a GT42
Old 09-03-2008, 04:25 PM
Hennytime's Avatar
so then im guessing its much larger than the tc78/7, about the size of a st80
LS1TECH Sponsor
DrTurbo's Avatar
Smaller in size, but ~ same comp flow.
Old 09-03-2008, 04:34 PM
Cool. I will buy one this winter.
Old 09-03-2008, 04:35 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yup similar to the ST80.
Also we will be finishing a unit that will bolt up to a PT88 turbine housing.
Old 09-03-2008, 10:13 PM
trey04gto's Avatar
Can you compare the new GT80 and the ST80?
Also these are a T4 flange correct?
Old 09-03-2008, 11:44 PM
Louis's Avatar
Hummmm.... What flow?
Old 09-04-2008, 12:12 AM
SuperZ's Avatar
I thought Precision already had a PT-88 with GT47-88 wheel in it
Old 09-04-2008, 10:07 AM
LS1TECH Sponsor
DrTurbo's Avatar
They are T6, like the S400's. The GT80 will outflow an ST80 due to the larger turbine wheel and T6 frame.
Old 09-04-2008, 10:08 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yes, but in the small H series cover. These use the full blown big covers like a S400 or GT42.
Old 09-04-2008, 10:09 AM
LS1TECH Sponsor
DrTurbo's Avatar
The unit will flow about 135lbs/min with that setup max. The T4 flange will be the limiting factor.
Old 09-04-2008, 04:49 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Those are really good prices on those. Can they be had in smaller ARs?
Quick Reply: Those that have asked about Garrett budget units....
