What CR for 408 w/F1
Old 09-03-2008, 02:27 PM
mr_biscuitz's Avatar
Default What CR for 408 w/F1
I think for now 14-16lbs will be enough. I want to make good power but I will need it to be safe on 93-94 octane. Thanks for any help
Old 09-03-2008, 02:29 PM
1INSANEGTO's Avatar
8.5:1 is what I am running on my 408ci with S91 turbo,
Old 09-03-2008, 02:41 PM
I've been thinking 8.5.1 to 9.5.1! Lots of guys are telling me to go as high as I can with the compression so I don't have to run lots of boost. This will be my first FI build so everything is new. Any help would be great. What fuel system do you run? How much power do you make? What boost? Thanks
Old 09-03-2008, 02:44 PM
Where did you buy your engine from? Lots of guys around here have LME engines. I am either thinking LME or Texas speed. I plan on buying a fully decked out shortblock.
Old 09-03-2008, 03:04 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'd run 9:1 and that makes it easy. Might be that some reccomend 9.5:1 because it also reflects a popular piston/rod/crank combo too.
Old 09-03-2008, 03:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
That is plenty with a big 408
Old 09-03-2008, 04:49 PM
crashinaz's Avatar
I'm at 9.4:1 with a 408 F1R... Go 9:1 or a little more with an average cc head (67 or so) and should you choose to run more boost and less compression in the future, you can get down to 8.6:1 by simply changing to a set of 72cc heads... ie: keep your options open without having to get into the shortblock.
Old 09-03-2008, 05:31 PM
MY99TAWS6's Avatar
I am 408 and went with 9.5 to 1. Plan on running alc injection all the time and car is street car. Possibly e85 when it becomes available here..if it becomes available here!
Wanted a bit more snap off boost and more compression pretty sure helps it spool up quicker. 9.1 seems like a nice middle ground and 8.5 is pretty common on cars that see huge boost and the track a lot. I am hoping to hit around 800 on auto or 850 rwhp on m6 with my setup at maybe 15psi.
Old 09-03-2008, 06:14 PM
Jake@EPP's Avatar
Alot of people tend to agree on 9:1 , the extra .5 wont gain a huge amount of power. If your looking for a snappier throttle response, then you most likely need a better cam or your have mixed matched componets.
For a bigger boosted car for pump fuel (~800rwhp) 9:1 is ideal, the added compression may lessen the amount of safe hp due to not running race fuel.
The turbo guys have been doing this for a while, low compression + high boost.
Eithe way, consult your engine builder to see what they recommend.
Quick Reply: What CR for 408 w/F1
