painting interior pieces
couldnt find **** in the search as usual but here is my question:
What would be the best way to paint interior plastic pieces? I am going to change my tan interior to ebony, or black. i still need to find carpet and door panels (for the vinyl) and seats obviously, but how should I paint the plastics? i dont think sanding them would be a good idea, but should i use adhesion promotor then just rattle can black? i dont want tiger stripe and i dont want my interior to stink like paint.
any suggestions?
any suggestions?
if you paint the interior use Gatorback Coatings..awesome stuff... Here is my interior from my old T/A to give you an idea https://ls1tech.com/forums/showthrea...687&highlight=
Just painted my interior back to black from yellow. Check it out:
https://ls1tech.com/forums/appearance-detailing/981154-surprise-surprise-bye-bye-yellow.html
I'm going to be doing a write-up tomorrow afternoon.
i want to do it the right way, ive painted motorcycle plastics before and they came out really well, but interior is different because its more of a flat color, not shiny, and i want to keep the texture in the panels. how would i paint these without them looking cheap and without sanding them flat?
this was my idea:
scotch brite surface
lay down adhesion promoter/primer
lay down primer
scotch brite loose paint
then paint them with some kinda of plastic paint...or should i use duplicolor type paints...i dont want it to chip off and i DONT want my interior to smell like paint.
this was my idea:
lay down primer
When i painted my dash pieces, i only used some "degreaser" on them. i had used armour all wipes on them about a week before. Cleaned them up and then sprayed them down with gloss black dupli-color vinyl paint. then hit them with a clear coat, and so far. They've held up, it's been about 2 months now.
I also left the pieces outside for a couple of hour's, before i put them back in. I didnt want the car to smell like paint, which it still did somewhat but not bad. Just keep window's cracked for a couple of day's and smell went away.
You can do it that way man, just going with my experience so far.
I've done pastic parts three ways. All involve getting all the armour all, factory mold release chemical, and scratches off. I personally like textured pastic but you can sand for a glassed look. My dash has chips from my knuckles banging gears over 6 yrs.
1. sand, wash parts
2. spary 3m adhesive grease remover or xylon
3. adhesive promotor
After this I've done different ways.
4. krylon pastic paint.
5. clear
or
4. primer
5. paint
6. clear coat
or
with vinyl
4. dupicolor interior vinyl pastic fabric paint.
5. clear
1. sand, wash parts
5. clear
or
4. primer
5. paint
6. clear coat
or
with vinyl
5. clear
the pieces im painting are the sail panel sides (where the rear speakers are) and the side moldings on the floor near the door because they are tan and i hate tan.
