OOPS... Just got kicked out of Great Lakes Dragaway for an 11.04@125 in a 96 IMP SS
Old 09-05-2008, 09:57 PM
nickate's Avatar
Default OOPS... Just got kicked out of Great Lakes Dragaway for an 11.04@125 in a 96 IMP SS
Car is set up for road racing and is on a DOT tire... 1.67 60'
This thing rocks!!!
I don't know much more other than it's a 383 with AFR heads, FAST ECM and VERY stock sounding!!!
There is no safety equip. so they tossed it out....
Shifting @ 5800 because if it goes to 6000 it will break up (Thought we fixed it with a new GM optispark but no luck)
HELP!!!!
WE NEED ANY SUGGESTIONS OR ADVICE AS TO THE HIGH RPM MISFIRE!!!!
It is NOT valve float--- has anyone had a similar experience with the FAST system???
Car will trap 128@6500 in drive but had to shift into OD because of the misfire problem...
It is not running to it's potential yet and when it does it should be a solid 10 sec. 4500lb. car that idles at 750 rpm WITH A/C!!!
And with the hood UP you see NOTHING...
Old 09-05-2008, 10:01 PM
LivingCanvas's Avatar
Video or it didnt happen
Old 09-05-2008, 10:02 PM
Fixxer99TA's Avatar
Nice, be sure to post up some pics/times when you get it all sorted out...
The stock opti does not last long above 6,000rpm, that could be your problem. Could I suggest an MSD opti or something similar like a Dynaspark?
Old 09-05-2008, 10:08 PM
1badzee's Avatar
Vid or i call b/s
Old 09-05-2008, 10:14 PM
shtnfrds's Avatar
why'd they kick you out?? unless you were a dick about it, id see them just shuttin your car down from running again.
Old 09-05-2008, 10:15 PM
Fixxer99TA's Avatar
Originally Posted by 1badzee
Vid or i call b/s
I would like to see a video too, but I am not calling BS yet for the sake of keeping the thread from turning into a shitshoot...
383lt1impala's Avatar
are u on the impala ss forum?
Old 09-05-2008, 10:17 PM
96capricemgr's Avatar
Look at post history.
In the past he said they were pulling a blower to replace it with a 400 shot. If they followed through and actually hit it with 400 and this is all it did then that is just sad other than having survived.
Definetely fast and I would guess they started with less than the full shot.
Maybe we will run into eachother come fall as I will get down to GLD a few times yet this season.
Old 09-05-2008, 10:49 PM
nickate's Avatar
We had rebuilt the motor and gone with an MSD unit but the high RPM gremlin showed up. We then replaced it with a NEW GM OPTI and thought the prob was solved... NOPE.
The nitrous is at about a 75% cycle and it is supposed to be 400 total HP.
We made 4 passes in the mid 11's@120 before they said anything... the 11.38 pass they told us to go talk to the tower...
He suggested we lift @ 1000 ft. until we feel everything is right (11.70@90mph)
until the last run.... he told us it WOULD be the last one of the night so make it "BANZAI".
We were not rude and I think they were amused watching the ET drop .2 EVERY pass!!!
Keeping the car in drive until 6500 without breaking up is what I'm looking for help with here... I have nothing to prove regarding the ET or MPH.... there was no video taken but I can post up slips...
IS ANYBODY ELSE USING A FAST engine management system that has worked through this hiccup????
PS... Thanks for all the responses believers or not.... (Wanna race?)
Old 09-05-2008, 10:54 PM
Fixxer99TA's Avatar
If you post up some slips, you would definitely quell the non-believers.
Good runs otherwise, wish I knew the FAST management system so I could help you.
Old 09-05-2008, 10:55 PM
nickate's Avatar
VERY ASTUTE comments.... YOU are correct...
It's a Black car with 2 BIG RED stripes...
Old 09-05-2008, 10:57 PM
1badzee's Avatar
Sounds like a fast *** b-body. Post some pics/vids if you wish
Old 09-05-2008, 11:08 PM
nickate's Avatar
The slip...
Attached Thumbnails OOPS...  Just got kicked out of Great Lakes Dragaway for an 11.04@125 in a 96 IMP SS-imp-ss.jpg
Old 09-05-2008, 11:10 PM
1badzee's Avatar
Good ****!
Old 09-05-2008, 11:46 PM
I8ASaleen's Avatar
Very nice. Tho at this point I'd almost look into a Bailey's LTCC system higher rpm spark.
Old 09-06-2008, 07:18 AM
the_merv's Avatar
Nice.. that thing's movin for a boat..
Old 09-06-2008, 07:58 AM
AINT SKEERED's Avatar
we are having the same high rpm miss and we have a msd optispark.
383 with 11.4/1 Trickflow heads
Old 09-06-2008, 08:25 AM
registered user
ScreaminRedZ's Avatar
Haven't had the pleasure of getting shut down for going too fast...yet. I hope to fix that next year
Badass car!
Old 09-06-2008, 10:04 AM
nickate's Avatar
WE REALLY NEED THAT 800 RPM!!! to keep the car out of OD. It has a 3.42 gear.
If we get it straightened out I'll post straight away...
Please do the same!
And good luck!
Old 09-06-2008, 10:12 AM
Formula350's Avatar
That's bragging rights for sure, not just the speed, but getting booted out of a track for it lol But no one can complain it's justified, they have safety to worry about, and their own *** if people get hurt.
Great job on not just hauling the mail, but hauling the whole ******* post office!!!
I concur on going LTCC. Or Ford EDIS for a bit cheaper way. (Here and Here for EDIS info)
Quick Reply: OOPS... Just got kicked out of Great Lakes Dragaway for an 11.04@125 in a 96 IMP SS
