Just bought a procharger what do i need????
Old 09-07-2008, 02:45 PM
99CAMMEDSS's Avatar
Question Just bought a procharger what do i need????
Ok so i just bought a prochager D1SC from a member here and im new to the forced induction world besides trubo diesels and would like to know mabe a list of what i need, im planning on probley around 500 rwhp, or watever you guys think is safe, also would it be safer to run 317 6.0 heads?, and also the cam in the sig should i swap it for a blower cam, would i gain or loose anything from switching cams? Whats the most boost i should run? Heres a list of what i think i need please edit or make changes to my list if im wrong.
Thanks for your replies...
317 heads
Ractronix fuel pump/wire kit
Injectors.....what size?????
tune
Boost guage
Widband
I already have fuel pressure guage
What am i missing ha???
Old 09-07-2008, 03:27 PM
xBROKEx's Avatar
id use different heads and 60lb injectors
Old 09-07-2008, 04:12 PM
98Z28MASS's Avatar
Id say cam swap, 317's, and a good fuel system (as mentioned above probably 60lbers but you could get away with 42s with a racetronix pump). I say cam swap because with that sized cam and boost your going to have a lot of stress on your valvesprings. You will make more power with the cam you have and the same amount of boost if you were to run it with a smaller cam but on a stock shortblock id just be careful. Tons of good blower cams out there, id just have one of the sponsors spec one out for you or buy an off the shell blower cam. I believe EPP has a good one that is in the 22x/22x range, which would give you good idle quality and power. Id say maybe look into a meth/alky injection kit as well as a safe guard. Let us know though what you choose and keep us updated on the build.
Old 09-07-2008, 05:03 PM
02NBMFormula's Avatar
dont forget the ati balancer and kit to pin the crank
Old 09-07-2008, 07:23 PM
99CAMMEDSS's Avatar
Im pretty sure it comes with a 6-rib setup with the pulley that bolts to the stock crank pulley, would that not work??
Old 09-08-2008, 02:28 AM
99BlownSS's Avatar
That would work thats what i have but mine is the p model
Old 09-08-2008, 02:31 AM
99BlownSS's Avatar
What type of inter cooler are you running if any?also the cooling fans. the stock ones are to big at least that they say.
Old 09-08-2008, 04:56 AM
EPP
EPP's Avatar
Thumbs up
The six rib kit will work at modest boost levels such as 8 psi. 8 psi is all I'd run on a stock bottom end, and we generally see an increase of 140 rwhp at this boost level.
Since you don't have fuel injectors yet, I'd go ahead and get 60lb injectors as has already been suggested.
If you need any piece parts, I have most of them listed here. A pdf of the ProCharger manual can also be found here. Bob
http://www.exoticperformanceplus.com...l?category=193
Old 09-08-2008, 09:10 AM
also, tr-6 spark plugs
Old 09-08-2008, 12:10 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
ummm 317 heads are NOT LS6 heads... LS6 heads are 243's. But yes, you should swap out your stock heads for some 317 heads cuz they will lower your compression a bit. And I'd change the cam too. I like the speed inc SC1 or SC2 for a stock short block or mild 347. But EPP has good blower cams too. They know their stuff when it comes to procharger! Don't hesitate to give Bob there a call and he can always steer you in the right direction. Oh and, 8psi should be the max you run on a stock short block. Make sure you get a good tune. And go with 60 #ers since you havent bought anything yet. It would be a good idea to start looking into an 8 rib kit too for the future...
Old 09-08-2008, 03:53 PM
99CAMMEDSS's Avatar
The kit come with the dual intercoolers and it comes with the shroud with slim single fan setup.
Old 09-08-2008, 03:56 PM
99CAMMEDSS's Avatar
Ha sry bout that just relized what i did.......
Old 09-08-2008, 04:00 PM
99CAMMEDSS's Avatar
The kit comes with a 3.2 and 4.0 pulley which one would i use to get that 8 pounds of boost?
Old 09-09-2008, 05:18 AM
EPP
EPP's Avatar
Neither, you're probably going to need a 3.55 to a 3.75 pulley for the six rib kit. Bob
Old 09-09-2008, 07:20 PM
99CAMMEDSS's Avatar
What kind of boost would i see with the pulleys that it comes with??
Old 09-10-2008, 04:28 AM
EPP
EPP's Avatar
The 4.0 pulley gave me 7 psi of boost on my 110,000 mile Z28 back in '02 with just headers and exhaust with no cats. Add a camshaft in there and it will make even less boost. The 3.2 pulley would more than likely give you belt slippage problems, and probably 12 psi of boost when it isn't slipping. Bob
Old 09-14-2008, 01:22 PM
99CAMMEDSS's Avatar
Question
Right now i have #853 heads with patriot performance dual vavle springs, when switching to 317 heads would i need to get different length pushrods or would i just need to swap them?
Is it worth swaping the 317 heads with my 853 heads,should it make 8 pounds of boost safer to run with the 317s or just keep the 853s and build a good motor later?
Thanks
Old 09-14-2008, 08:20 PM
99CAMMEDSS's Avatar
Anybody????
Old 09-14-2008, 09:24 PM
'Trust''s Avatar
853's suck, but you're going to see more boost with them since they are more restrictive, but you'll make the same power. I'd give Bob a call over at EPP, he helped the shop out that was having a couple of issues with my car during tuning, good guys over there.
Old 09-15-2008, 04:35 AM
EPP
EPP's Avatar
Thumbs up
Thanks, I appreciate it!
Personally, I'd keep the heads you have on the engine for the time being. If you do end up changing to the 317 heads the same length of pushrods (7.40) should be what you need. Bob
Quick Reply: Just bought a procharger what do i need????
