07 z71 truck...wanna put lsx fbody intake?
6.0 engine, i wanan try and get a ls6 intake.
do i absolutely have to change my injectors? (undersand diff lenghts?)
do i have to absolultely change my fuel rails?
or can i use my stock rails and injectors (both off truck, not fbody) with the ls6 intake?
Is the engine still in the truck? Or are you placing it in the Camaro?
If it's in the truck, you will have to swap the accessory drive setup to a car type to clear the lower throttle body placement.
As for the truck injectors, you will have to get a kit to make them fit the correct rail for the intake. Or swap out the connectors for the LS-1 injectors and use the whole LS-1 intake, injectors, and rail setup.
If its a LQ9 then it will fit all you need is an L92 water pump and injector plug adapters.
