9" Experts?
Old 09-08-2008, 04:57 PM
DTB_LS1's Avatar
Default 9" Experts?
I currently have a 2000 m6 camaro with a 9" rearend that make 402rwhp and 375rwtq N/A and will be making 500-550rwhp and 550-600rwtq on spray. My rearend is equipped a Moser housing, Strange aluminum center section, Tru Trac posi, and Moser 31 spline axles. I have been having problems with my Tru Trac and I think I may have broke it so I will be swapping it out for a spool with 4.11 gears. I would like to know if the 31 spline axles will hold up to 550-600rwtq? Basically I'm asking how many people are running a spool with 31 spline axles in high hp/tq m6 cars?
Old 09-08-2008, 05:35 PM
TT632's Avatar
Ive ran 31 spline aftermarket axles with more than 600 rwtq and they survived. What ended up breaking on that car was a factory 3rd member.
Old 09-08-2008, 06:28 PM
DTB_LS1's Avatar
Thanks for the reply, what trans and differential were you running?
Old 09-08-2008, 07:05 PM
TT632's Avatar
T400 and a stock Ford big car 9 inch 3rd member and a spool. 4:46 gears and a 29x12.50 slick. Nodular 3rd member and quality pinion support seemed to fix the issue.
Old 09-08-2008, 07:08 PM
adam1803's Avatar
31 spline will take 600rwtq all day long. Like already said, make sure your 3rd member is up to the task.
Old 09-08-2008, 08:28 PM
DTB_LS1's Avatar
Cool, my third member is a Strange Aluminum S series with a daytona pinion support and a Tru Trac. I'm not the most educated person about 9" rears but, I assume these are good parts for my application.
Old 09-08-2008, 08:29 PM
DTB_LS1's Avatar
Any suggestions on weather or not I should keep the tru trac or ditch it for a spool? This car is a summer car and driven often but, I'm not overly concerned about tire scrub, chriping, or other driving issues. I'm willing to sacrifice a little drivability for strength. I just want to make sure my rear will take a 5000-6000rpm launch on spray.
Old 09-08-2008, 08:37 PM
Dark Shadow's Avatar
no you will hate the spool wile driveing in the city and trying to turn.
Old 09-08-2008, 10:34 PM
DTB_LS1's Avatar
does anyone else have any input on a street driven car with a spool. As I said before I'm willing to sacrifice some driveability for strength. I just don't see the tru trac holding up to the abuse of an m6 car like a spool would.
Old 09-09-2008, 08:59 AM
ajrothm's Avatar
I had a spool in a 78 trans am and hated it on the street. U-turns or tight turns in parking lots suck....Especially in the long *** F-bodies. You might try a Detroit locker. Its probably the median between a spool and true track. I am discouraged hearing you are having problems with your true track as I just installed a 9" in my car last night with a true track. I don't race a lot but will definetly hit the strip on ET streets 3-4 times a year and some street action....I am putting around 540hp down.....Hope it holds.
Old 09-09-2008, 11:15 AM
adam1803's Avatar
I personally wouldn't run a spool on the street. Im putting a locker in my 9" right now and i'll let you know how it is on the street. I do hear alot of people complain about a locker with a 6spd car.
Old 09-09-2008, 10:34 PM
TT632's Avatar
spools are all Ive had on street/strip cars. The only time you will regret it for sure, is if you have to push the car with the wheel turned
Old 09-10-2008, 03:26 AM
blk00ss's Avatar
I have a six speed car and a spool. It's most definately not as bad as everyone makes it out to be. It seems as tho soft tires and big sidewalls help a TON. In my opion a spool is way more streetable than a locker, in a stick car that is. A locker in an automatic car is not bad at all.
Old 09-10-2008, 04:13 AM
EPP
EPP's Avatar
I'd swap out the Truetrac for the spool if your Truetrac has problems with it. You're planning on coming out at a high rpm with nitrous, I feel the spool would be the best way to go. While you are at it, I would swap out the axles for 35 spline axles. Bob
Old 09-10-2008, 01:09 PM
DTB_LS1's Avatar
Thanks, for the info Bob. I'm up in the air right now about going with a Detroit Soft Locker or a spool. I have a Strange aluminum case in the car and was told that I couldn't upgrade to 35 spline axles because the case doesn't have enough clearance. Can you shead some light on this please?
