wanting to go with LE1 kit, but not sure what all is needed
Old 09-11-2008, 02:14 PM
badzee28's Avatar
Default wanting to go with LE1 kit, but not sure what all is needed
Well, let me start off by telling you the specs of my car, just got it the past july, it's a 94 Z28 with SLP cold air intake, Hooker exhaust, and pace setter headers. The tact just hit 90 thousand miles, but overally mechanically I would say it's been very well taken care of and the previous owner replaced a few thing such as the fuel pump, water, spark plugs, opti, etc before it was sold. I also have a seperate intake ported to accept a 58 mm throttle body that I haven't installed yet. I just got a 2400 dollar refund check from my school so I was looking at a LE1 porting job from Lloyd Elliot, but I'm not really sure what's required/ needed when all is said and done. I would love to do the labor part myself, but living in a college dorm that really isn't feasable because I have nowhere to work on it, and I don't have the proper tool to do it. That and I'm pretty much a newb when it comes to ripping down LT1's especially and I really don't want to screw up my new vehicle. So... this leads to question if that 2400 bucks will be able to cover everything needed before I go in over my head.
Old 09-11-2008, 02:42 PM
AChotrod's Avatar
Probably not unless you got a guy 2 install it for you. Unless your going to use the stock cam . Then you could probably do it.
Old 09-11-2008, 02:57 PM
lt1z28camaro's Avatar
Parts you will most likely need. Or "want to replace" while it's out and open.
Lifters
Roller rockers
Pushrods
New Springs
Guide plates
Timing Chain
Cam
The port job of course
Tune
Possibly Injectors depending on cam
It adds up alot quicker than you expect (i'm in the process right now)
Good luck
oh and labor costs expect anywhere between 1200-2000 depending on area and who you know (you may have a friend that could help out alot and store car at his place or something)
This is all for a cam and heads installed.
Old 09-11-2008, 03:05 PM
PNYKLR-TA's Avatar
I Heard Lloyds Lowest Kit The Le1 Was Like 1100 Bucks? That Would Leave Him With A Good Amount Of Money Still Unless The Le1 Is More.
Old 09-11-2008, 03:28 PM
whammer33024's Avatar
LE1 is 1200 with a cam. comes with new springs
Old 09-11-2008, 03:46 PM
AChotrod's Avatar
Its everything else plus labor that will put him over the top.
Old 09-11-2008, 04:13 PM
PNYKLR-TA's Avatar
YEA BUT HE IS DECENTLY CLOSE IF THAT COMES WITH THE HEADS CAM AND NEW SPRINGS. ALL HE NEEDS IS INSTALL AND MAYBE 1.6RR'S AND SOME PUSHRODS AND LIFTERS IF NECESARY SO IF ANYTHING HE MIGHT BE 200-300 SHORT WHICH REALLY ISNT TOO BAD.
Old 06-01-2010, 09:52 PM
94lt1camaro's Avatar
where can i get the LE1 kit at..cant find it..someone help..
Old 06-01-2010, 10:07 PM
Rockstar
Johnny-LT1-runner's Avatar
LE2 would be a better investment IMO, it's just a bit more.
Old 06-01-2010, 10:11 PM
djm_e22's Avatar
I might be going solid roller so I am debating on selling my LE1 heads. I made 403rwhp with these heads, LE ported intake, 306 cam, 58mm throttle body though a m6 and 9" rear end. I might also sell the ported intake, 306 cam, and the PCM that was tuned by Moe Bailey. But you will need 42lb injectors if you use this PCM since that is what he tuned it with. Plus my engine is a 355 so if yours is still a 350 I am not sure how much that will affect on whether or not the PCM will need to be retuned if you did decide to buy my PCM as well.
Old 06-02-2010, 10:27 AM
MasterTomos's Avatar
this post is from 2008
but all of elliot portworks stuff can be found on their site...http://elliottsportworks.com/ (click on the "LT1" button )
Old 06-02-2010, 01:37 PM
BLK,97,T/A,M-6's Avatar
Everyone always forgets the gaskets, the fluids, the tune, the head bolts... If you want to do a H/C/I car, and dont have the means to do the labor yourself, your looking at a $5000 project.
Your much better off doing a 125 wet shot, tune and a stall if auto.
Old 06-02-2010, 06:20 PM
That seems quite high, even for labor.
Quick Reply: wanting to go with LE1 kit, but not sure what all is needed
