Lost A/C and coolant temperature at the same time.
So, driving to work, my a/c suddenly stops being cold, and I notice my coolant gauge is now reading completely cold.
I know the temp gauge was working when I left, since I don't drive away until the car's temp gauge starts to move up a bit.
Factory gauge on a 2006 GTO.
The gauge still has power, and all the other gauges work fine, but it's like this gauge isn't getting a reading.
I'm wondering if since it's not getting a reading, if maybe the a/c won't engage the a/c clutch since it can't tell how hot the car is.
Just guessing here, gonna put in a new coolant sensor since it only costs like 15 bucks.
Hi, my GTO 2006 water pump started leaking, havent replaced it yet but I been driving an refilling the the coolant as it lowers, for maybe a few days before i take it to replace, but all of a sudden the coolant temp gauge stopped working. Where is the temp sensor mounted ? (you mentioned your have replace it...) . Is it in the in the radiator iteself, or in the water pump, or ?.... Thanks
