combustion chamber size to achieve 12:1 compression w/ truck heads.
Anyone know what size combustion chamber will produce 12 to 1 compression with truck heads and a stock gm head gasket? How much milling is generally necessary to achieve this?
Re: combustion chamber size to achieve 12:1 compression w/ truck heads.
Right about 54ccs chambers would be needed. Without doing the math they would need to be milled about .050-.060 or so.
Thanks Paul! I just sent you guys an email with the same question. Will an ls6 intake fit properly on truck heads milled .060?
<small>[ February 10, 2003, 03:07 PM: Message edited by: Stu'sWS6 ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Stu'sWS6:
<strong> Thanks Paul! I just sent you guys an email with the same question. Will an ls6 intake fit properly on truck heads milled .060? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That will be on the edge but it should seal fine.
Paul
Paul
Went with the TR230-couldn't pass it up with the sale they had going on. If I don't reach my goals with the tr230, I'll swap it out for something bigger. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
