combustion chamber size to achieve 12:1 compression w/ truck heads.
Old 02-10-2003, 02:27 PM
Stu'sWS6's Avatar
Default combustion chamber size to achieve 12:1 compression w/ truck heads.
Anyone know what size combustion chamber will produce 12 to 1 compression with truck heads and a stock gm head gasket? How much milling is generally necessary to achieve this?
Old 02-10-2003, 02:57 PM
Paul F's Avatar
Default Re: combustion chamber size to achieve 12:1 compression w/ truck heads.
Right about 54ccs chambers would be needed. Without doing the math they would need to be milled about .050-.060 or so.
Old 02-10-2003, 03:05 PM
Stu'sWS6's Avatar
Thanks Paul! I just sent you guys an email with the same question. Will an ls6 intake fit properly on truck heads milled .060?
<small>[ February 10, 2003, 03:07 PM: Message edited by: Stu'sWS6 ]</small>
Old 02-10-2003, 03:44 PM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Stu'sWS6:
<strong> Thanks Paul! I just sent you guys an email with the same question. Will an ls6 intake fit properly on truck heads milled .060? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That will be on the edge but it should seal fine.
Paul
Old 02-10-2003, 05:11 PM
gator's 99TA's Avatar
travis, 12/1 compression! hell ya, i would go with that in a heartbeat if my pistons could support it. have any idea what cam you are going to?
Old 02-10-2003, 05:31 PM
Stu'sWS6's Avatar
Went with the TR230-couldn't pass it up with the sale they had going on. If I don't reach my goals with the tr230, I'll swap it out for something bigger. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
