Going to track later, guess my times
Old 09-16-2008, 09:18 AM
Purple95Z28's Avatar
Default Going to track later, guess my times
I should be heading to the track later today hopefully, so tell me what you think I'll run
6-speed
355 w/ GM 847 cam, about 10.85:1 compression
heads are 99% stock, they were very lightly hand ported but not gasket matched or anything
bolt ons (exhaust, cold air)
MadZ mail order tune
4.10s
Nitto drag radials on a pair of salad shooters
Old 09-16-2008, 09:22 AM
z28rob18's Avatar
idk the specs of that cam but ima guess 13.0-12.8 let us no how it runs
Old 09-16-2008, 09:45 AM
IrocZ's Avatar
What headers are on it?
Old 09-16-2008, 09:47 AM
coated Pacesetter LTs
The rest of the exhaust is 2.5" true duals over the axle with 2 sweet thunder mufflers.
Old 09-16-2008, 10:27 AM
TABBED 5.3's Avatar
Old 09-16-2008, 10:29 AM
96lt1m6's Avatar
6-speed
4.10s
A few more questions:
what injectors
1.5,1.6 rockers
throttle body
tires
altitude,temp,humidity,barometric pressure.
i would say low 12s w/traction depending on driving skillzz
Old 09-16-2008, 10:35 AM
grn95t/a's Avatar
12.50's
Old 09-16-2008, 10:40 AM
what injectors
1.5,1.6 rockers
throttle body
tires
30lb injectors
1.6 rockers
stock TB
Nitto DRs, 245/50/16 on the salad shooters
I think the track is about 750ft ASL, and it should be fairly dry and in the 60's tonight
Old 09-16-2008, 11:39 AM
kinglt-1's Avatar
12.6 at 112
Old 09-16-2008, 11:40 AM
connexion2005's Avatar
Originally Posted by grn95t/a
12.50's
Exactly my guess. It depends on what 60's you are able to pull but I will guess 12.40-12.80 throughout your runs.
This is given you can pull a 2.00 60 ft.
Traps should be 112-116mph...
Old 09-16-2008, 11:43 AM
12.50's is my guess too And I think traps will be about 114, maybe 115 area. I should be able to get at least 2.0 60's out of it
Old 09-16-2008, 11:49 AM
If you leave the line around 2,500rpm and do not spin a 2.0x is going to happen. Be carefull going into the upper 3,000rpm range these rear ends don't like it with an m6. I've broken 3 already...
Old 09-16-2008, 12:00 PM
Yeah, I'm REALLY hoping I won't grenade the rear end... I'll keep it to 2500 or so and cross my fingers...
Old 09-16-2008, 12:01 PM
I think you will be ok at that RPM. Just don't straight drop the clutch try to ride it out of the hole.
Old 09-16-2008, 12:03 PM
This clutch tends towards the "on or off" variety, lol
Old 09-16-2008, 12:05 PM
Which one are you running? I know what you mean though. It may take a pass or two but the best way to preserve these things is after you second stage bring the clutch up to the point to where it is damn near about to roll forward but don't go to far or you will redlight. That will put you at the friction point and allow you to ride it out. It's kind of tricky at first though...
Old 09-16-2008, 12:08 PM
It's a Powergrip HD
Someone else told me to get the clutch just up to its initial grab point and hold my foot on the brakes as well (like you would when starting a brake stand), because that well take out any driveline "slack" and make the launch less harsh. It makes sense to me but it seems like it would be easy to screw up.
Old 09-16-2008, 12:40 PM
k0261886's Avatar
Unless you get ur dick down there to hold the brake pedal that is going to be hard to do, lol.
But in all reality, maybe use the E-brake?
Old 09-16-2008, 12:51 PM
C_Rules's Avatar
I'm going to say 12.70s. But i hope you run quicker.
Old 09-16-2008, 12:56 PM
haha, well I don't have one so that wouldn't be an option anyway.
But it's very possibly to do, I do it all the time. You just use your right foot, heel on the brake, toes on the gas - clutch in with the left foot, then punch the gas with your toes, drop the clutch, and then you can move your left to the brake and the right to the gas.
Silly automatic drivers
edit: That would be for doing a brakestand, but the same technique applies to holding the car still with the clutch out slightly while being staged
Quick Reply: Going to track later, guess my times
