Solid Crush sleave
Solid Crush sleave
Does anyone happen to have any extras? And is it really worth it? Also, how can I tell if the one I have is a solid or regular?
thanks!
-Karl
thanks!
-Karl
The only advantage to the solid sleeve is that it is reuseable. I think its tough to shim it properly, thats why i preffer the stock sleeve. It crushes to exactly where it needs to be, no guess work involved.
Moderator
The solid one is just a stack of shims and a tubular hard
collar. If you're just replacing the crush collar (or believe
factory tolerances are tight enough) you can get close or
even perfect by mic'ing the old collar and assembling the
same height out of the pieces. My 3.23->3.42 swap went
fine like that, perfect, no whine and no drips out the snout
either. Anyway you can get close / lucky like that. Though
the pattern wants checked properly before you call it done.
The hard collar kit is only like $20-$30 from Ratech as I recall.
I bought the total rebuild kit since I had a whole mess of
stock Torsen shavings in the pumpkin.
I swapped the crush sleeve out of my Strange 12-bolt for one of their solid kits.
From someone that does a lot of Jeep axles for people, I HATE crush sleeves. Once they're crushed, they're done. You have to put so much torque on them to get them crushing. Then be careful not to over torque. I almost always buy an extra sleeve or two if I know Im going to be doing some gear setups.
The solid sleeve is a cake walk. You start off like jimmyblue said. Mic the crush sleeve, and set your solid spacer up at that spec. Thats your starting point. Crank the pinion nut down with an air gun, check the pre-load, make a couple quick small adjustments and bam, youre done. If you need to take it apart for some reason...no muss, no fuss. Take it apart, put it back together.
So far Im liking mine. Ide like to track some down for the 8.8 because I do a lot of those for people. Never really thought to look.
J.
J.
