Comp. Ratio for this boost application...
What compression would you run.
I am going to build a 408 to run NA until i can run boost. I want to run up to 20-22 lbs of boost when all said and done. I plan on running on E80/E85. What compression would you build the motor for 9.0?
10.0-10.5 will be good.. but why stress on a boost level like 22 psi its just a number i will do the math for my set upi beleive it was 9.5-1 with 72 cc heads and i went with 64cc heads and spoling was not a prob just got to tune it right and take your time
I just want to maximize power with boost.
