who's pushing a 200 shot with a single nozzle?
Old 10-01-2008, 04:10 PM
maggiemike's Avatar
Default who's pushing a 200 shot with a single nozzle?
just tryin to see what kind of nozzle people are using. I want to be able to push 200 through my single nozzle and just want to know what nozzles people have done it with. let me know if you have made 200 wheel on a dyno or if it was just jetted for 200 too if you can
Old 10-02-2008, 09:26 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the NX shark, NX SHO, and our 1/8 NPT nozzle will all easily flow that amount.
Old 10-02-2008, 09:35 AM
Nick@HSW's Avatar
Just about all of the 1/8NPT nozzles on the market today will flow that much. Just make sure the rest of the kit is up to the challenge.
Nick
Old 10-02-2008, 09:56 AM
maggiemike's Avatar
alright good to know, because my friend's Mach 1 with nitrous, the one I beat last night with a 150 shot and the NOS soft plume nozzle, he's sure to do something to try and get a little edge on me, so i'll be looking into a better nozzle and a little more juice.
Old 10-02-2008, 10:02 AM
nahasapeemapetalon's Avatar
I am doing about 180rwhp shot. Something is holding back bigger jets. I have a shark nozzle. I have read they dont recommend much more with a single nozzle, the distribution of the mixture begins to have problems.
Old 10-02-2008, 10:42 AM
maggiemike's Avatar
hmmm hmmmm hmmmmm maybe dual nozzles is a better idea
Old 10-02-2008, 10:47 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
for 200 I would run a plate or even direct port if you think you might go bigger later
Old 10-02-2008, 10:48 AM
maggiemike's Avatar
so what 1/8" nozzles are there out there? I have come up with three: NX S.H.O, Nitrous Outlet, and the HSW Black Mamba. Just checked and found a couple more, the TNT, the Ny-Trex, and the Coldfusion Predator.
Old 10-02-2008, 10:57 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
its an old thread but has a lot of information on nozzles in it.
https://ls1tech.com/forums/showthrea...ht=test+nozzle
it won't have some of the newer stuff in it, but the data is still pertinent
Old 10-02-2008, 11:01 AM
Frans96SS's Avatar
I ran a 200 on a single nozzle kit. I think after 200 the -4 line is almost a restriction.
Old 10-02-2008, 11:15 AM
maggiemike's Avatar
Yea, I really do like the plate setups, and I think that if I were to decide to do a second nozzle, i'd probably do the plate instead of buying the nozzle and a couple lines and more jets.
Old 10-02-2008, 11:45 AM
Johnnystock's Avatar
I like the idea of a single nozzle because its downright simple for a DIY like me. Plus, large shot thru a single nozzle has been done before and my HSW black mamba nozzle can handle up to 350shot!! 200 wouldnt scare me at all. I plan on doing a 200-250 shot one day, but I need to upgrade the noids.
Old 10-02-2008, 11:55 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
The issue is not flow capacity but cylinder distribution. The plates give you more distribution points which will give you better atomization. This will improve cylinder distribution.
Old 10-02-2008, 12:45 PM
Yeah, plates are simple too and baddass. Better atomization has to be better for the engine!
OP (and me)should look for plates too around with the 200pill..
Quick Reply: who's pushing a 200 shot with a single nozzle?
