Parts list, is there anything else i need?
Old 10-02-2008, 06:11 PM
HotRod68Camaro's Avatar
Default Parts list, is there anything else i need?
I currently have a ZEX nitrous system on the Z06. Personally i would have chosen another system but it came with the Z so i might as well use it. I want to make it safer to run since its bare bones right now. Could someone look over this parts list and tell me if there is anything i am missing.
Blow Down Tube
Bottle Heater & Blanket
FJO Progressive Controller
and either a Dyno Tune Lean Shut-Down Switch or a FPSS
I will also be converting the system to a 90mm Plate from Nitrous Outlet.
Do i need Nitrous & Fuel Pressure Gauges?
Old 10-02-2008, 06:32 PM
Nitro Dave's Nitrous Outlet's Avatar
Unfortintly if you want to stick with the ZEX system you will not be able to run a progressive controller. Your best bet would be to get the ZEX windowswitch as it comes with a gear lock out feature and it wires directly into the Zex system with ease.
The rest looks pretty well. Dont forget spark plugs. I am not 100 percent sure about the Dynotune lean cut out switch if it will owrk in conjuction with the ZEX system. I know either Chris or Ray was helping a guy the other day with one. I can ask them in the morning when I get to work.
Dave
Old 10-02-2008, 06:53 PM
I really wanted to run the progressive. Hmm maybe ill just go with an entirely new kit.
Old 10-02-2008, 06:55 PM
How much are you looking to spray?
Dave
Old 10-02-2008, 07:08 PM
150, maybe 175 max.
Old 10-03-2008, 11:31 AM
Chris@NitroDaves
Guest
Posts: n/a
I would at least put a Nitrous pressure gauge in the item list so that away you can monitor the pressure.
Old 10-03-2008, 11:39 AM
If you are concerned with traction on the street and still want to keep it simple the Zex windowswitch will let you lock out first gear. This will let you get moving before the nitrous hits.
Ofcourse I would be happy to help you put together a full system if you would like but I think you can make what you have work.
Dave
Old 10-03-2008, 12:48 PM
Traction and trying to prolong the life of my drivetrain are my main concerns.
Old 10-03-2008, 01:37 PM
Its kind of a toss up. But you should be able to plant a 150hp to the road with bringing it in in second gear. Ofcourse a progressive will give you more tunability.
If you want to go another route check out the specials we have posted. We could upgrade the windowswitch to the progressive and you would have everything.
Dave
Old 10-03-2008, 05:20 PM
Sounds like its going to come down to how much i want to spend and if i can deal with having a purple nitrous system
Old 10-06-2008, 12:55 PM
LOl. Your probley right.. You could always paint the ZEX box.. Or sale it and put the money towrads a new set up.
Dave
Old 10-06-2008, 01:10 PM
Yea, I would sell it but it doesn't seem like anybody wants to buy the Zex systems. I think i may end up trying to move it into the batery tray area. I might try to put the Zex up for sale for a week and if there aren't any takers just keep it, since it should work alright and i don't plan on going for more than a 175 shot. I got an email out with Chris to see about the parts. In another thread you mentioned possibly making a plate with the inlets on the bottom. How much would something like that run?
Old 10-07-2008, 03:03 PM
Ill have to go look and see if there is enough clearance room to do that with the 78mm intake.
Dave
Old 10-07-2008, 03:37 PM
Im actually running a FAST 90 on the vette.
Old 10-08-2008, 10:48 PM
=ZoomZ='s Avatar
Wide band 02 sensor/gauge .
And yes you will be glad to have fuel and nitrous gauges in the hot summer and cold winter when running nitrous .
Get one of these ,,
http://www.harrisspeedworks.com/shop...age=1&featured
And one of these and tie them together .
http://www.jegs.com/p/Innovate+Motor...74546/10002/-1
