finally got into the 11's NA
hey guys i have a 94 camaro lt1 355 its got a 230/236 duration cam, stock ported heads, bolt ons, and a 3600 fuddle stall converter, and believe it or not still has stock ten bolt with 3.23 gears. i took it to richmond dragway tonight and ran it a couple of times it was having valve float issues braking up everytime before shifting to 3rd which easily i shurting me a tenth of a second. the best timeslip of the night.
1.57 60 ft
4.79 330ft
7.53 @90 1/8
11.98 @112 1/4
but man does this thing launch like a bat outta hell i couldn't beleive the 60 ft i got. all other runs were 12.00s with one 1.59 60ft and the others low low 1.6s once i get things situated i'm hopin for some 11.70's next time out so well see
1.57 60 ft
4.79 330ft
7.53 @90 1/8
11.98 @112 1/4
That's awesome man
Go post the timeslip in the 11sec club area so they can add you to the club
That's a very good launch for 3.23s and a 3600 stall.
What suspension mods to you have installed?
Get those valve float issues under control and you should be able to hit 11.7s.
What valvesprings are you running? Are they installed at the proper height?
And are the rockers adjusted properly?
suspension mods are bmr torque arm, airbag in rr sping 18 psi, lakewood lower control arms, umi subframe connectors, panhard bar, and relocation brackets, and kyb shocks, and removed front sway bar, everything else is still stock.
my valvesprings are comp cam 918 beehives. i am going to check them out this weekend and readjust the rockers and see if that helps b/c i no its still leavin alot on hte table. thanks for the comments guys keep em comin.
