How many High HP(1000RWHP) are running a Bottom end Girdle???
Just like it says. Is it a need or a want. I can only find that DMperformance.com is the only people making them. And I've seen that EPP has used them in a few of there builds.
Will it make a differnce on a LS2 402 Stroker running close to or over 1000rwhp. There about $550 for the race version.
Thanks Jordan
Thanks Jordan
i agree on the Dowels > girdle. it will save bearing life.
the girdle is kind of a waste imo. i personally am just running stock caps... but if i would have known better at the time, i would have pinned them. not worried about flex at all.
jordan!!! Stop over thinking your built and put some boost to it! Most people i know dont even run them on ther near 2000hp builds.You'll lift the heads off you motor LONG before you have main cap issues on a ls2 block.
I am using the DM - Girdle/ARP stud kit , in my forged LS6 246 boost motor just for extra insurance.
I was told at the time i bought it that if i was running stock crank and caps, the girdle will save the bottom end, stranghten it and prevent movement and flex.
My Machine shop that is putting my race together as we speak said it cant hurt, but dont see it doing much, as of preventing flex etc, They also said no need to pin the caps, but i am only looking for 700 HP.
And i am using a Callies drangonslayer crank too.
TT-TECH Veteran
I have them on both of my cars and after doing it I would agree more with this statement haven't had any real issues yet, but I think the pininng keeps the blocks from flexing as much and the mains haven't really been a major issue as far as HP goes. The W2W girdle was an intergrated with the maincaps and tied into the oil pan rails but was pricey due to the process of installation and over kill for anything but all out race motors.
Ok thats what I needed to know. And Bryan its coming along. Both the turbos were out when it dyno'ed 730rwhp. So I'm upgrading to bigger ones with new inlets made, FAST 92mm intake and TB, New PVC system, 100mm MAF, and a few other odd and in things.
LS1Tech Co-Founder
