Will my combo make 700RWHP
Old 10-07-2008, 01:08 AM
Restricted User
Lawnboy's Avatar
Default Will my combo make 700RWHP
Hi , I am building a 346 forged LS6 motor
(Diamond -8.6 blower pistons, Eagle H-beams, callies dragonslayer, DM-Girdle W/ARP main studes)
LS1 241 AS ported heads, 300CFM at .600
TR 216-231 601/580 116 Blower camshaft
FLP long tubes, no cats, SLP DD exhaust
LS6 intake/acufab 75mm ported throttle body.
D1-sc twin intercooled / alky control methanol injection
OK I need to know what you guys think, I would like to run 93 pump gas with the methanol injection (no race fuel)
I want to make around or very close to 700 RWHP.
1) Can my combo make 700RWHP?
2) How much boost will i have to make (15)?
3) with 8 rib set up and 7.65 crank pully , what size blower pully do i use,
thank you for your help
Old 10-07-2008, 02:01 AM
MY99TAWS6's Avatar
Too bad the search is down. I would think you should reach 700rwhp by 15psi or so. Depends on if you are auto or m6 too. m6 of course read higher rwhp than autos especially some unlocked autos.
Old 10-07-2008, 02:42 AM
Spoolin's Avatar
I think with 15psi you'll see low/mid 600's depending on your tranny. Automatics lose between %15-20 power and Manuals between %10-15.
Old 10-07-2008, 03:09 AM
venom ws7's Avatar
Check EPP Website 14+psi with the right H/C D1SC they always get 730+rwhp on Mustang Dyno.
I say this combo will get you 680+rwhp very easy depends on the boost and the tuner.
Old 10-07-2008, 04:16 AM
TT-TECH Veteran
Inspector12's Avatar
Took me 10-11 lbs to make 600rwhp on a 347. Very simular parts cam was a 224/230 and Hookers 13/4" I was gaining about 30-40rwhp per every pound of boost so @14-15 should do it pretty easy assuming everything work right GL!
Old 10-07-2008, 04:23 AM
EPP
EPP's Avatar
Your combination should get you similar results to this build that we did.
http://www.exoticperformanceplus.com...Car.php?car=54
You are going to need a good fuel system for 700 rwhp, and I would go with a 3.40 blower pulley. Bob
Old 10-07-2008, 10:09 AM
Restricted User
Lawnboy's Avatar
My car is a M-6 , That should help in getting the 700.
I have both 3.65 and 3.4 blower pullies, the 3.4 is the smallest you can use procharger said.
My fuel system is a Lonnies Performance/Racetronix intank double pumper, Speed inc fuel rails, and motron #60's
Alky control , LS1 methanol injection system
I was going to run the returnless stock fuel system for now, (no return) I hear i can make 700RWHP without a return.
Tunner = My friend Carmen (Vette Doctors)
Old 10-07-2008, 10:14 AM
Restricted User
Lawnboy's Avatar
O yeah, should i get a Casper LS1 Volt Booster? For a little more juice to the pumps.
I have a new KennyBell boost a pump , but the Kenny bell is for at least + 6 volts.
The casper is only a 1-2 volt booster and it boost the spark to.
let me know what you guys think.
Thanks
