Turn signal
I'm in the same boat only its my left side that's out. It just stays lit and doesn't blink when I use the signal. I hope its not the case but, I think its in the mulitfunction switch. Anyone else have any suggestions for 2 TA owners?
Copy & Paste Moderator
i still dont know what it is. The side that works the short filament flashes but on the other side on short and one tall flash the tall filament isnt as bright. And when the turn signal is on that side just stays on.
It seems mine was a filament issue. I had to take it out of the socket and look very closely at it but it was broken. I will go tomorrow to get another bulb and let you know if that fixed it.
Incidentally, I found my front signal socket to be quite burnt looking so I replace it thinking that was the problem. Just a stroke of luck that I found it while my rears were the problem.
