L92 heads + boost
Old 10-09-2008, 04:14 PM
RPM Motorsports's Avatar
Default L92 heads + boost
How would a set of stock L92 heads flow on a LQ9 6.0L block that has been bored out to 6.7L with twin turbos?
I've read a few guys are using these heads with this block combo and most are making pretty good power. Now what if you added boost?
Whatdya think?
Old 10-09-2008, 04:23 PM
LS1TECH Sponsor
DrTurbo's Avatar
I understood from a few customers that they are pretty thin.
Old 10-10-2008, 01:33 AM
tomz28's Avatar
what do you mean thin?
Old 10-10-2008, 01:40 AM
Dark Shadow's Avatar
+1
Old 10-10-2008, 02:35 AM
valiant65's Avatar
Some say that L92 castings are thinner than catethralports and therefore substantially thinner than aftermarket castings. But, several people still use them succesfully on boosted applications, so I think it is more matter of knowledge than material thickness.
Another point of using L92s or not is the exhaust/intake flow ratio. My opinion is that turboengines like lots of exhaustport flow and the intake flow could anyways be corrected by upping boost.
Also have been wondering a lot why people want to stroke their turboengines. I am gathering parts for my 6.0 buildup and I want to make the shortblock as reliable as possible (within lowbudget ofcourse), so engine must be geometrically as good as possible. I think the rod/stroke-ratio is the keyword with any engine and especially with boost engines because you don't want to stress the engine geometrically, there will be just enough dynamic stress. I will be using stock stroke and maybe even stock crank...
Old 10-10-2008, 06:25 AM
pwrtrip75's Avatar
The runners are thinner? So that means you cant run 50+ psi of boost? That sucks I guess they are junk.
Old 10-10-2008, 07:04 AM
LS1Tech Sponsor
hellbents10's Avatar
Less deck not runner, this leads to the heads lifting a little early. Although I have not seen them really lift sooner (hp wise) myself.
Old 10-10-2008, 07:44 AM
fenix999's Avatar
lifting early as in what 700-800hp with a boosted application? "Lifting early" can be different for everyone according to their past experiences, im sure you've had alot of exeperience so if you could clarify and/or give out some numbers so we get a better perspective on whats "early" to you, it would be greatly appreciated!!
Old 10-10-2008, 07:49 AM
camaroandreas's Avatar
Lifting is not a deck issue itīs a gasket issue. I Boost 35 psi with stock heads and ordinary ARP studs, but not with MLS.
Old 10-10-2008, 08:09 AM
bluecamaroz28's Avatar
What gasket are you using for 35 psi?
Old 10-10-2008, 08:10 AM
LS1Tech Sponsor
I assure you its a issue of having 4 bolts per cyl. and the deck height. I can make 35psi and not have them lift either if the engine is a dog and doesn't make power. Its a matter of hp more then boost. At about 900-1000fwhp I would expect to start moving water after multiple passes. If making 1200+ it will happen sooner then later. This is why people with o-rings and copper gaskets and even bigger studs still move water eventually.
Old 10-10-2008, 08:19 AM
Rickys S/C Z28's Avatar
so if i want 700ish i should not need to worrie about the heads lifting if the tune is good right??
Old 10-10-2008, 08:54 AM
Mr.Big's Avatar
Originally Posted by Rickys S/C Z28
so if i want 700ish i should not need to worry about the heads lifting if the tune is good right??
You should have ZERO issues... I don't, at 30,000 plus boosted miles...
Old 10-10-2008, 09:16 AM
LS1Tech Sponsor
Exactly, they usually have no problem till you cross the 850whp mark.
Old 10-10-2008, 11:43 AM
1CAMWNDR's Avatar
OK, so up to say 850 rwhp the L92 should work.
Now back to the exhaust port. Would it be good to have a CNC'd exhaust port with a 1.6" valve and 3 angle valve job and pair that with a stock intake port and valve size and a 3 angle valve job? Would it still need a traditional split cam like NA, or would a straight cam be better?
Old 10-10-2008, 12:39 PM
so how about cooper spraying 5 layer mls gaskets to keeping from pushing water?
Old 10-10-2008, 12:55 PM
LS1TECH Sponsor
DrTurbo's Avatar
That's correct...... We have had customers call saying they have had problems keeping their heads down.
Old 10-10-2008, 01:44 PM
LS1Tech Sponsor
If you are looking for 800 or so whp then I would do some porting on the exhaust and run a ls7 cam, should work well for your power level. Or just save the money and run 317's and still make 800+whp. No need to spend a ton of money on cylinder heads to make a easy 800. If any thing I would foot the cash for some afr's with the thick deck and then have a better chance of keeping them down under boost.
Old 10-10-2008, 03:23 PM
1CAMWNDR's Avatar
I wouldn't think a turbo with a fairly common 2-3:1 backpressure to boost ratio would like all of that extra exhaust duration on the LS7 cam.
Old 10-11-2008, 03:14 PM
I have 1170 hp in my 6.0 lit on a engine dyno. Itīs 1000+ whp on a dynojet.
But i donīt use mls gaskets..
Never pushed any water at all.
Quick Reply: L92 heads + boost
