fuel pump wiring...size/routing
For a 1st gen Fbody did folks route the wiring thru the car or along the frame rail? What gauge wiring did most folks use? I was thinking 12-14 gauge wiring?
Bob
Bob
I ran my fuel pump wire through the firewall and then along side the factory tail light and fuel level sender wires (inside the car down the left side), and then in the trunk ran it through same gromet as the fuel sender.
I ran 10awg 600v copper house wiring. I see 14.4v all day long at my fuel pump. It just creates less of a voltage drop. I ran a hot and a ground to make sure it would get a good voltage as i was worried about fuel starvation with only a 97gph pump but its working fine. I also ran mine like rodder did with the signal wires except that i ran mine though the trunk pan where my pump mounts.
