need some help... crank pulley??
Old 01-15-2009, 09:22 AM
cherrygxp's Avatar
Default need some help... crank pulley??
can anyone fire up their car let it get to operating temp idle and look at your crank pulley and tell me if it wobbles a little at idle. Im getting a rattle from somewhere in that area and i thought it was the tensioner pulley but now ive noticed the crank pulley is wobbling a little.
Old 01-15-2009, 10:39 AM
cherrygxp's Avatar
c'mon guys no one else is sitting at work with nothing else to do
Old 01-15-2009, 10:44 AM
Bryan921SS's Avatar
ooo ooo ooo me me me, nothing to do but it's -2 outside, so sorry....
Old 01-15-2009, 10:54 AM
neilownz's Avatar
-26 here. -2 is like shorts weather
Old 01-15-2009, 11:25 AM
cherrygxp's Avatar
o come on its 9 here and i was outside for 3 hours this morning and im still in and out. Just use your electric start then run out and look.
Old 01-15-2009, 11:39 AM
LS1Tech Sponsor
06MonteSS's Avatar
no wobble on mine that I can see or hear...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 01-15-2009, 12:22 PM
Mels SS's Avatar
No wobble and its 53 here great weather
Old 01-15-2009, 01:33 PM
cherrygxp's Avatar
thanks guys. this cant be good
Old 01-15-2009, 03:29 PM
1BADCTS's Avatar
Doh! Hope it 's not the thrust bearing going out... the same thing has happened on our intrepid. It started out just with a little noise, then got worse until a few weeks later it's full blown engine knock! Now that we know what to look for we can see the play in the crank pully.
*edit* Does the noise go away when you apply throttle?
Old 01-15-2009, 05:48 PM
cherrygxp's Avatar
yes the noise pretty much goes away with throttle. i believe the noise is from the tensioner pulley which i will be tackling asap. does anyone have any idea why else there may be a little wobble in the crank pulley. as soon as rpms go up it is as straight as an arrow. My boat does the same minor wobble and has never had a problem knock on wood
Old 01-15-2009, 06:22 PM
1BADCTS's Avatar
Yea, start with the pulley's first. In my case we had a slight noise that went away with throttle... then developed into full engine knock, but it still went away with throttle. Turns out the thrust bearing was shot, and when you apply throttle the crank would push one way or the other and stop making noise until the RPM's came back down.
Old 01-15-2009, 06:33 PM
cherrygxp's Avatar
hmmm hope the pulley is the noise. hopefully the crank is just nothing
Quick Reply: need some help... crank pulley??
