the ss is down again!
Old 02-20-2009, 10:03 PM
layitlow's Avatar
Default the ss is down again!
so about a week ago my transmission went out and since i got it rebuilt i've babied it, and then tonite it started dying everytime i come to a stop and running rough at low speeds, then after it died 5 times the check stability light came one i dont know whats up with this car this is the first gm i've ever had problems with. does anyone have any ideas of what this could be?
Old 02-21-2009, 12:16 AM
neilownz's Avatar
take it back and have whomever did it fix it since they caused it. at least say that etc esp if it was a dealer...
Old 02-21-2009, 01:34 AM
HardBlu's Avatar
Take it back. Sounds like a vacuum line came off. Check all of your lines to make sure they are on tight.
Old 02-23-2009, 03:01 PM
layitlow's Avatar
i got it back today and they said it was something in the fuel pump, i wonder how long it will be before its back at the dealer again
Old 02-23-2009, 03:53 PM
ImpSS07's Avatar
How many miles did you have on it before your tranny went out?
Old 02-23-2009, 09:34 PM
CenTexSS's Avatar
Did they explain exactly what it was? I'd want to know what's going on with my car and know if they're just BSing me.
Old 02-24-2009, 04:25 PM
Roadrally SS's Avatar
Angry
Mine went at 28,000
Old 02-24-2009, 08:09 PM
Hell'sChariot's Avatar
Nothing bad has happened to me yet...but I wish I had not bought this car.
Old 02-24-2009, 09:50 PM
layitlow's Avatar
8060 miles
Old 02-24-2009, 09:53 PM
layitlow's Avatar
i think there bs'in me about it because they said it was in the fuel pump but when it started dying the check stabilitrac message was on and the check traction control. and i had onstar run a probe on it and they said it was the abs, then the dealer said it wasnt trowing any codes
Old 02-24-2009, 09:55 PM
layitlow's Avatar
im with you on that one! all i want is my 63 i traded on it back
Old 02-24-2009, 09:58 PM
Yes! I would do anything to get my Camaro back. Im such a idiot!
Old 02-24-2009, 10:05 PM
ChefChub's Avatar
Mine went out at 22k then again at 48k lol... The second time was the dealers fault because they rebuilt it and put everything together all wrong.
Old 02-25-2009, 12:15 AM
layitlow's Avatar
i think they fucked up rebuilding mine too, sometimes it will shift to 2nd early then go back and forth to first and there is like an inch of play between gears when i shift it manualy
Old 03-20-2009, 10:47 PM
ckso226's Avatar
I'm getting pretty sick of this car. I can name a list of things that suck about it. Only thing i think is good about it is the LS4 engine. Everything else is pretty much mediocre or below. This car in my opinion wasn't made well enough to handle a v8. Probably going to trade in for a nice durable crown vic in the near future.
My own personal list:
1. Trans slips in the 1-2 shift 50% of the time
2. Headlights flicker when turned on. Sometimes only 1 turns on.
3. Bose stereo noticeable hissing sound when volume is low.
4. Horrible rear seat room/leg space.
5. Trunk is too big, and not that necessary.
6. blind spots.
7. FWD
Old 03-21-2009, 11:09 AM
VenomGXP's Avatar
6. blind spots.
7. FWD
Ugh... You knew about half of those things when you bought it...
Old 03-21-2009, 12:27 PM
Panther427's Avatar
Fuel pump sounds liike a B/S thing. The codes that onstar came up with are for the trans
