Installed LED tail bulbs
Old 03-29-2010, 01:25 PM
jabronie78's Avatar
Default Installed LED tail bulbs
I don't like the LED after market tails so I thought I would try and do my own. Bought some bulbs and the load resistors. Was pretty easy to install.
A couple complaints though. Website said you would only need two load resistors, one for each side since they are on the same circuit. You can install them in the front or back. Hooked them up but when I installed the front turn signal led's I got the bulb out flash on the dash. So I will probably have to get 4 of them, one for each bulb. Probably go to RS and get some cheap ones.
Other complaint, when the headlights are on the brake lights and turn signal lights don't light up too much more.
I sent a set of tails to be tinted so we will see what the leds look like with those
I actually bought 4 bulbs for the back and the two load resistors.
For the MC you splice into the the white and black wires on the lower bulb.
stock
http://s166.photobucket.com/albums/u...rent=stock.flv
LEDs
http://s166.photobucket.com/albums/u...rrent=leds.flv
Old 03-29-2010, 01:26 PM
jabronie78's Avatar
LEDs
Old 03-29-2010, 04:18 PM
RickAKATed10's Avatar
It's cool, but I don't really see a difference.
Old 03-29-2010, 04:34 PM
Model16's Avatar
What's the difference, Just brighter???
Old 03-29-2010, 05:13 PM
Nick_Nasty's_GXP's Avatar
I thought the stocks were brighter
Old 03-29-2010, 05:42 PM
jabronie78's Avatar
The LEDs are brighter and the light goes on and off faster.
It's hard to tell in the video but you can tell the difference.
Old 03-29-2010, 05:58 PM
TheMonteMan's Avatar
i didnt really see the difference either. im sure in person you can tell. should have done one side with the led and one side stock at night.
Old 03-29-2010, 06:02 PM
Model16's Avatar
how much did those LEDs run you each?
I looked some up on V-LEDs and they were like 70 dollars a piece..ouch lol
Old 03-29-2010, 06:07 PM
jabronie78's Avatar
I'll try and take some night shots and put the stockers in on one side.
I got them off Ebay and they were $55 for all 4
Old 03-30-2010, 06:39 PM
jabronie78's Avatar
Alright took a couple more videos. I think I am going to return the bulbs and try a different type. They are brighter than stock and fill out the tail light better but they don't light up enough when you turn on the signals or the brakes.
The left side is the LED bulb
http://s166.photobucket.com/albums/u...rent=leds1.flv
jabronie78's Avatar
http://s166.photobucket.com/albums/u...rent=leds2.flv
Old 03-31-2010, 02:01 PM
Yeah, they appear bright and better colored until they flash. Pretty weird.
Old 03-31-2010, 02:59 PM
not going to lie to you i dont think the difference is worth it.
Old 03-31-2010, 03:08 PM
94ss06gxp's Avatar
i give you credit for buying them and trying them out for sure
Old 03-31-2010, 03:13 PM
Breathing Fire's Avatar
Nice man. It isn't something you can tell in a video. The color is more vivid and on/off instantly is nice. Best thing is they will probably outlast the car. Love my LED's in my TA. Takes some work, but worth it. Nice work OP.
Old 03-31-2010, 03:51 PM
Nacho SS's Avatar
Uhh stock still looks brighter to me.
Old 03-31-2010, 04:35 PM
jabronie78's Avatar
The video is ****, in person it is more noticable. The LEDs are brighter and look better than the stock ones without the brake or blinker on. The leds just don't light up enough when you hit the brake or blinker.
I am going to try some different bulbs that have a better high to low ratio that should do the trick or not who knows.
Old 03-31-2010, 06:57 PM
mike690003's Avatar
If I show you how I did LED tails on my 2000 Monte, you'd flip!
Take a dremel and some 4" LED modules and a ton of silicone:
Old 04-01-2010, 11:10 AM
jabronie78's Avatar
That looks pretty cool.
If I just find some decent bulbs I will be happy.
Old 04-01-2010, 11:18 AM
That's both awesome and unique, but I do not like the amber.
