Planning my cam install
So this coming winter i plan on installing a cam into my ls4. Now, what i need to know is what other things i will need to buy and install along with the cam. I want an aggressive cam as i dont care for the DOD, any input on what cam(links to website would be awsome also) and what other items I will need is greatly appreciated.
Thanks.
Thanks.
Here you go.. These are my secret links.
http://forums.trailvoy.com/archive/i...p/t-61781.html
http://www.g8board.com/forums/showthread.php?t=11196
http://www.ls2.com/forums/showthread.php?p=12351739
And this is the kit that I would like to go with. Not a bad price at around 2800.00
http://www.trickflow.com/partdetail....5&autoview=sku
Thanks for the links.
you need cam, pushrods, springs, timing gear, different lifters, valve spring compressor, compressed air tool, something to remove the belt, a way to lift the car up to get enough clearance to remove/ install the cam, jack, stands, coolant for when you leak some, loctite and depending on whether or not you reuse the gaskets, water pump gasket, timing cover gasket and valve cover gaskets.........and of course tools.
And I do believe that's a run-on sentence.
