Need opinion's
Old 11-26-2010, 09:11 PM
Mels SS's Avatar
Default Need opinion's
I had a dash plaque made should I place it on the dash by the passenger side or on the main part of the dash right under the DIC Controls Take a look.
I know it blurry but it's the best I could take
Old 11-26-2010, 09:25 PM
JP_GXP's Avatar
Post up a pic of your interior so I can decide.
Old 11-26-2010, 10:25 PM
Mels SS's Avatar
Ok
Here is a pic
Old 11-26-2010, 10:32 PM
Mels SS's Avatar
This is where I'm thinking
Old 11-26-2010, 10:39 PM
JP_GXP's Avatar
Seems like the best place for it. Or in front of the gear selector, but it would be looked over there.
Old 11-26-2010, 11:23 PM
DrJesus616's Avatar
youre going to need some thicker double sided tape, because without going out to my car ( its effing freezing out ) i think that spot under the DIC controls has a bit of a curve to it ...
its not that its the best spot, i think its really the only spot unless you put it on the passenger airbag ... which wouldnt be a bad spot either ... because lets face it, shes a garage queen
Old 11-27-2010, 01:00 AM
The Guz's Avatar
I would say in front of the geear selector area or the passenger side dash would be a good spot for it.
Old 11-27-2010, 06:33 AM
LuSe4's Avatar
Will it fit betwen the two left/ right vent adjusters that are located directly above the radio? It might look nice there. Or in the area between the radio and hvac controls. (I like things to be centered! )
Old 11-27-2010, 07:03 AM
Mels SS's Avatar
1. Explain??( its effing freezing out ) No it's almost flat
2. unless you put it on the passenger airbag . Agreed
It has a bow to it and the shifter blocks it.
1. No a little to long by the vent's
2. If I change out the radio to a Nav System I would have to remove it.
Old 11-27-2010, 07:12 AM
LuSe4's Avatar
True, but you can buy more two sided tape and reapply it anywhere you want. I keep a couple of rolls in my toolbox, it is very handy.
Old 11-27-2010, 07:32 AM
Mels SS's Avatar
Show what type you use.
Old 11-27-2010, 09:02 AM
LuSe4's Avatar
It is by 3M. I got it at one of the parts stores. It comes in a roll. One is probably 1/4" - 1/2" wide, the other is maybe 3/4" wide. It is the same stuff that is used for emblems and moldings.
Old 11-27-2010, 05:21 PM
Mgpeagle's Avatar
1. Pass-air bag
2. top gear selector (in drive it will be seen great.)
3. Under DIC controls
-Mike
Old 11-27-2010, 07:25 PM
MC06SS's Avatar
I think it would be fine below the DIC controls.. If it were mine, I would probably put the emblem in front of the shifter though...
Old 11-27-2010, 07:37 PM
DrJesus616's Avatar
it was just too cold to wanna go out to the car to look for you, but now that im typing this, im going to walk out to my car right now ...
hang on ... BRB
yeah, under the DIC controls on the silver part, or on the black plastic next to the ignition under the DIC ... looks to be the best spot ...
Old 11-27-2010, 11:18 PM
Mels SS's Avatar
Well it's under the DIC controls I will post a pic tomorrow.
Old 11-28-2010, 11:24 AM
gxp-miller-gxp's Avatar
i would put it where you decided so in the picture
Old 11-28-2010, 12:17 PM
crazyjoe's Avatar
Post that pic! I had a factory GXP badge on the passender side of the dash, but it just wasnt strong enough to hold for very long. Hopefully you'll have better luck than I did of getting it to stay!
Old 11-29-2010, 11:11 AM
jediknight120's Avatar
Pics!!
