Another Slipping GXP Transmission- CAI affect Warranty?
Old 12-15-2010, 10:01 PM
98GTcoupe's Avatar
Default Another Slipping GXP Transmission- CAI affect Warranty?
Hey all,
Well i broke down and called the dealer today. Gotta take the car in tomorrow morning. It started out slipping all day untill after work and didnt miss a beat. So, hopefully it will act up at the dealer and not play possum.
I reloaded my factory tune and removed any sign of a tuner from the car.
It was doing the reving then going into gear from a stop and then slipping into 2nd and 3rd gear. I checked the level tonight its right on the money but does smell a bit odd. Kinda burnt but not to bad. Also there seemed to be some kinda dirt/debree on the dip stick when i first pulled it out.
Oh well thats why we have a warranty.
Oh and has anyone with a CAI had a dealer give them **** about it adding to the loss of the transmission??
Thanks,
Greg
Old 12-15-2010, 10:06 PM
AlabamaGuy's Avatar
Only one way to find out! lol
Why not put the stock stuff back on?
Old 12-15-2010, 10:09 PM
98GTcoupe's Avatar
Yeah no **** right.... I have the stock **** somewheres..... Ah screw it Ill take it in as she sits.....
Maybe....
Old 12-15-2010, 10:40 PM
ls4door's Avatar
They can't void your warranty for a CAI. Mine was acting like it was slipping today. Shuddering vibration into second and third. But again once it warmed up seemed fine.
Old 12-16-2010, 06:34 AM
06 SS's Avatar
yes, they can make a case for a CAI causing tranny problems as it can change the values that the sensors use to determine shift parameters.
Old 12-16-2010, 06:53 AM
indynotch50's Avatar
They can and will void your warranty, depending on the dealer of course.
It's just my opinion, but I would make a good effort of finding the stock stuff and putting it on.
Old 12-16-2010, 11:58 AM
LS1 Racing's Avatar
Make it stock if you don't want to buy a transmission for it. You're at the mercy of the dealer, and if the tech who gets assigned your car is having a bad day (Boss yelled at him, just found out the teen daughter is pregnant, wife didn't put out last night, etc.) it will cost you upwards of $3k for p&l.
Don't chance it.
Old 12-16-2010, 01:39 PM
EmersonHart13's Avatar
Go back to stock, it is just easier than arguing with the dealer.
Old 12-16-2010, 10:50 PM
ls4door's Avatar
Just going off what my dealer told me. Long as it bolt on and not changing parts on the engine itself (rockers cam etc) that they can't. Maybe vary by state?
Old 12-16-2010, 11:24 PM
LS1 Racing's Avatar
That's a reasonable position for the dealer to take, but unfortunately, each one is different. According to the Magnuson-Moss Warranty act, the modification would have to be directly related to the failure. Whether or not the a CAI could cause the failure would be something that a court would have to decide, so would you even want to fight that battle?
Old 12-16-2010, 11:36 PM
DrJesus616's Avatar
they didnt give me **** for the CAI when i took mine in today ...
Old 12-16-2010, 11:44 PM
LS1 Racing's Avatar
Well, if they don't make an issue of it, then you're fortunate. Many others have not been so lucky.
Old 12-16-2010, 11:52 PM
DrJesus616's Avatar
completely understandable however ... that a dealer would be unwilling to cover warranty work when there is something clearly modified ...
IMO, if you know enough about cars, or start to modify stuff ... chances are, youre going to keep going and a CAI would be the start of it ...
i can tell you what though ... after mine gets all fixed ( hopefully ... really crossing my fingers ) once my warranty is up in May ... its getting a Lewtune, shift kit, and tranny cooler ...
im already saving up ... lol
Old 12-16-2010, 11:56 PM
LS1 Racing's Avatar
Definitely.
You also ought to consider the TEP valvebody and a Sonnax converter relief valve, as well as the "long sleeve" seal kit. It amounts to a partial rebuild, but should also prevent most of the trans issues our LS4 cars having. I'm getting that stuff done right now.
Old 12-17-2010, 02:15 AM
DrJesus616's Avatar
Definitely.
can that all be purchased from a common distributor ??
ill for sure keep it all in mind, because if they do give me a rebuild, or fix mine in some way, im not exactly sure what causes our problems ... im only going to have a few months left of warranty anyways, so it would be prudent to protect it as best as possible as soon as possible ... once the warranty is done that is ...
Old 12-17-2010, 09:50 AM
Purchase Here: http://www.tripleedgeperformance.com/
What has to be done to replace the converter release valve?
Old 12-17-2010, 10:03 AM
Ill_Born_ss's Avatar
Go here : http://www.sonnax.com/part_finder.ph..._only_sc=false
scroll to thepart you are interested in and click the PN , it will show you the part and offer instructions
Old 12-17-2010, 10:21 PM
98GTcoupe's Avatar
Well,
I totally bitched out and didnt bring it in. It didnt miss a beat the next day so whaaaatever.
But I will be throwing the stock **** back on just because of the fact I dont feel like arguing with the service manager anywhere that it might blow...
Thanks fellas!
Ya know I love LS1tech, you all seem to actually give a damn..
Old 12-17-2010, 10:47 PM
LS1 Racing's Avatar
Originally Posted by 98GTcoupe
Well,
Thanks fellas!
I wouldn't say you "bitched out"...You just wised up! Much better to safe than sorry!
