Flipped motor mount
Flipped motor mount
Ok guys, maybe I am a total DA but here goes, Since we were experiencing an Ice storm here in Ohio today I decided to work on the Monte, so I changed the oil and flipped the motor mount, I have not driven the car yet, but I fail to see how doing this will make any difference, I just took the wishbone off and turned it over... Is this what you are talking about... if I am way off base let me know and post a picture.. Thanks
Yep. like I said I cannot see how that would make a difference.. I was looking at that rubber piece and thinking about rolling that too, but didn't . Thanks
LS1Tech Sponsor
yeah, it's the rubber mount inside the dog bone, not the dog bone itself, hehe...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
How the heck do you get the rubber part out of the metal mount to "flip" it?? I'm assuming we're talking about the square bushing that sits in the metal bracket that mounts to the radiator support, correct??
LS1Tech Sponsor
if you're just going to flip it over, there's no need to take it out.. just put a ratchet/wrench on the bolt on either side of it... lube up the 4 sides of it with some wd-40, then TWIST/TURN that ****!! and it will flip right over...
if you are replacing it altogether with a poly mount, like I did... then just lube it all up all over the place, and use a big-*** flat-head screwdriver and you can push/pry it out, all in once piece... no need to hack/cut it all up like others say they had to do... they were just impatient... hehe...
__________________
Even though you flip it it still has some play, have someone rev your engine and watch.
Watch how much it still rocks with it flipped. All the yellow is gone, btw...
http://www.youtube.com/watch?v=d8CRJb8CgBU
Could the rocking, or movement actually alleviate stress on the engine and transmission?
In other words, with everything stiffened up, could it actually cause things to become too harsh?
