cruise control dosent work with predator tune
Is it not supposed to? I installed the predator tune with DOD delete and raised the shift points to 6100.
LS1Tech Sponsor
first off... you can't change the shift points... you can raise the rev limiter, but it does you no good anyway unless you shift manually...
second.. yes, with the No DOD tune, you're cruise control will not work.. it's a GXP-only issue...
press the Traction Control button on your dash, and the cruise should work...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
if your cruise control is not working, then someone hosed your tune... or you have an issue with your car....
__________________
