Going back to Ultras
Switching back to SilverStar Ultras. I've had nothing but bad luck with every kind of Bulb blowing in the passenger side headlight. H.I.D.'s=Blown bulb,Xenon Bulbs=Blown Bulb....Everything blows with the exception of The SS Ultras.
Yes they are expensive but compared to buying a new bulb every 4-6 months vs. spending the money upfront 1 time it's really cheaper....And those damn H.I.D. bulbs?????...Fugettaboutit,LoL.
I've had the same pair of DDM HIDs in my Impala for two years with no problems.
If you keep blowing bulbs on the same side, then maybe you ought to try to troubleshoot the wiring to that headlight.
Also, when you ran the HIDs, were you running a relay harness?
When I was running the H.I.D.'s I was using relays and the harnesses. The problem began befors the H.I.D.'s were ever installed though. Xenons went in like the day after purchase. Wemt through various bulbs then to Ultras & 2 H.I.D.'s and finally to back 2 Ultras. Had the wiring checked and nothing was wrong. Just a freak from the factory.
Hi guys tonight on my way home from work my pasinger side headlight went out I got out tapped on the assembly it came back on than I drive over a bump on the road and it went back out agen my question is are my low beam lights on my gxp 9005 or 9006 bulbs??
Also I just looked into the silver star ultra bulbs I can get a twin pack for $36 with my discount is that a good deal or should I go with hids or a cheap bulb what are some opinions
Okay I have The Ultras installed and I hate them,LoL. After The Blue Xenons the dullness of the Ultras leaves a lot to be desired. Someone here suggested Osrams....I might have to give them a try.
Ultras are known to blow after a few months. In my 99 grand prix I use philips xtreme power in the headlights and osram nightbreakers in the fogs. Best combo that I have had. As an FYI anything with a blue costing on the bulb limits light output. The ultras are blue coated to make them appear whiter.
Haven't had any Ultras blow on me yet,infact they're the only 1's that don't blow. I've always switched to somethong else before I've ever had to change 1. Curious about those Osram's though.
I had problems with my hids untill I shut off the feature that turns the lights on when I unlock the car. That with the relay I haven't had any problems. It's something with our auto lights not giving the correct power for the ballast. I never had any problems with my fog lights and they are always on.
